1" drop front, .5" drop rear
Old Mar 14, 2002 | 04:57 AM
AutoXsi2000's Avatar
Default 1" drop front, .5" drop rear
00'Si. Would you guys recommend getting an alignment or should I wait a couple of weeks and order a camber kit then get the alignment?
Old Mar 14, 2002 | 05:10 AM
TurboBumblBee's Avatar
Default Re: 1" drop front, .5" drop rear (mano77)
with that much of a drop i would honestly not worry about getting an aglianment or even a chamber.. im dropped 2.5/2.25 and its not that bad at all..
but if you do want to get an aligment then i would get the chamber kit then get it aliagned and done the correct way..
Old Mar 14, 2002 | 05:31 AM
Default Re: 1" drop front, .5" drop rear (95CivicEX)
ok thanks
Old Mar 14, 2002 | 07:05 AM
blackDA's Avatar
you'll need an alignment but I wouldn't get a camber kit. the camber on a drop that small would be corrected with an alignment.(I think)
Old Mar 14, 2002 | 07:14 AM
KF_S2000's Avatar
Default Re: 1" drop front, .5" drop rear (greyeg)
Well, on 5th and 6th gen Civics, the camber is not adjustable. With a drop that moderate, skip the camber kit. Just get the alignment. Your camber settings will still be within factory specs.
Old Mar 14, 2002 | 08:17 AM
GoLowDrew's Avatar
Old Member
25 Year Member
If your car still track straight, save your money. You may not need an aligment at all.
Old Mar 14, 2002 | 08:35 AM
wakaru's Avatar
With that slight of a drop, don't sweat the camber kit. Definately do get the alignment. Contrary to what some may think, an alignment is for far more than just making a car "track straight". Any drop will affect toe settings, and toe settings too far from the norm can cause other problems like poor turn-in, understeer, squirrely high-speed handling and excessive tire wear.
Rule of thumb is that anytime you change ride height with the intention of driving on it, get the toe set.
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
shibbywhitedude
Sep 6, 2007 03:04 PM
es_squared
Apr 3, 2004 02:04 AM
AllMotorITR
Jun 27, 2001 10:58 PM
