distributor on d16a6 block n d16z6 head..which one?
so i have a minime.. a d16a6 block and a z6head, i really need a distributor. what would be the best one? where can i get it? n about how much?
if you have and obd0 ecu meaning the pm6 the stock ecu you have couple choices.
1. use z6 head and a6 distributor, only two bolts match up though so you will have to do some modding, you will have to get something to activate vtec
2. use a z6 distrib and p28 computer with z6 distributor but you will have to convert to obd-1, are conversion harness is now available for very cheap
now you can do the conversion to obd-1 yourself, but i will be honest with you would you like to spend a couple hours or couple days getting your swap done?
Randysi
Mar 5, 2012 02:39 PM
Randysi
49
Oct 30, 2011 09:54 PM
88EDHatch
Dec 3, 2010 10:02 AM
