problems with ground control extended top mounts
i just bought the ground control top mounts for koni yellow with ground control coil overs but It says to use the stock sleeves that came with koni.
i never recieved any stock sleeves with the gc/koni. i used my stock mounts and it had a small metal sleeve. Am i suppose to reuse that one? if i do it doesnt give me as much thread for the luck nuts as before
Do you have to order this sleeve from koni? just wondering
Modified by racekar711 at 6:35 PM 12/2/2005
The stock metal sleeve is the same length as the koni sleeve - some cars you can use the stock ones, other ones (integra) are too small and you need to use the koni sleeve. If it fits over teh shocks, use 'em.
Iloveyourhonda92
Suspension & Brakes
10
Nov 2, 2010 10:45 PM
93SIRII
Feb 7, 2009 06:45 PM
steve00si
19
Nov 30, 2004 07:37 PM
