z6 head on b7 block , can i use b7 timing belt?
i searched but didnt find any specifics about what timing belt i must use. im putting a z6 head on my del sol 1.5L d15b7 block, what timing belt must i use ? im gonna use a metal z6 headgasket also. i was told a p 28 is the ecu i should use. is there anywhere i can find the wiring harness changes that must be made to run this ecu . i have a del sol S . 93
Use the z6 timing belt. You use the belt that will work for the head.
Search on here for a while, you should be able to find out what harness you need and how to make it work.
ok . i found how to wire vtec and all . does my del sol S need the IACV fix or no? also the vtec head came with a distributor but the ignitor and coil are missing. can i use my 93 d15b7 dist on the vtec head or if not can i take the ignitor and coil out of mine and use it inside the z6 distributor?
pip9
Apr 3, 2006 07:09 PM
Layziebtnh055
Jun 6, 2004 07:59 AM
hatchback19
Feb 29, 2004 10:56 AM
