Fuel Smell
Are you one hundred percent there isn't a leak? I would recommend cleaning the area, water is good, so any fuel/fuel residue is gone. After a nice drive, pop the hood and see if you smell it again; smell present = leak.
Do what that guy said man. Try it. Check all your lines. Check to see if it's a defective filter. Check all your lines/connection. Inspect your tank and straps. Check everyting. Fuel leaks are really bad.
hey guys
yea i looked at it now and the line was a little bit off and it pinched something and it was spraying out. I loosened the line and put it back on, and now everything it good. Thanks for your help.
