can u get 190whp off of 1.8L?
Old Mar 13, 2002 | 10:44 PM
BoM's Avatar
BoM
Default can u get 190whp off of 1.8L?
GSR
well more specifically
can u hit that with oem internals?
ctr pistons, itr cams ect...stock bore
Old Mar 14, 2002 | 03:55 AM
Pineapple Devil's Avatar
Default Re: can u get 190whp off of 1.8L? (BoM)
sure can.
Old Mar 14, 2002 | 04:36 AM
gsr stuie's Avatar
Default Re: can u get 190whp off of 1.8L? (Pineapple Devil)
up. Force induction........
Old Mar 14, 2002 | 05:24 AM
Tegman10's Avatar
sure, with I/H/E and some cams tund correctly you should be up around 190, if lucky more.
Old Mar 14, 2002 | 05:56 AM
alexboy's Avatar
thats what i am aiming for at least . All motor but no stock internals
Old Mar 14, 2002 | 06:32 AM
Trey's Avatar
25 Year Member
Default Re: can u get 190whp off of 1.8L? (alexboy)
ITR crank and JDM ITR pistons with a CTR head:
Old Mar 14, 2002 | 07:08 AM
BoM's Avatar
BoM
Default Re: can u get 190whp off of 1.8L? (Trey)
thats nice torque on that chart.
CTR head flows as good as the ITR? im not familiar with it
right now i run 14.7's with i/h/e and suspension in my gsr
if i got the ITR cams could i get fast as a type R? (14.4)
then later i wanted the S2k Intake manifold, cam gears, vafc, with a chipped ecu.
is that 13's? after its tuned?
Old Mar 14, 2002 | 08:30 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: can u get 190whp off of 1.8L? (Tegman10)
No way. Cams alone won't get you there. Look at the post above. Quite a bit of internals are needed. i/h/e basically only increase the efficiency of air flow into the motor. The motor is still producing the same power.
A really aggressive cam might net you 20whp, but then you need springs/retainers, and at least some sort of fuel managment to control your idle.
With run of the mill cams, and your i/h/e like you mentioned, you might get 170-175whp if you're lucky.
Old Mar 14, 2002 | 09:32 AM
4U2NV's Avatar
A friend of mine has a JDM 1.8L GSR in a hatch and he put down 192 CHP all motor... He has Skunk 2 IM, I/H/E, ITR cams, underdrive pulley, and FPR and I think that's it... I'll have to do some more research to make sure that's it but I'm pretty sure that's all... However, the JDM motor does come stock with more flywheel horespower than US spec GSR motor...
[Modified by Sick GS Teg, 6:39 PM 3/14/2002]
Old Mar 14, 2002 | 09:37 AM
LOwrestling2001's Avatar
Default Re: can u get 190whp off of 1.8L? (Sick GS Teg)
JDM gsr motor? naw i think it's the same HP as the USDM...for GSRs at least...just higher compression 10.6:1 as opposed to 10:1 which does make a big diff
Old Mar 14, 2002 | 10:16 AM
junglistgsr's Avatar
Default Re: can u get 190whp off of 1.8L? (LOwrestling2001)
no such thing as a JDM GSR guys.
Old Mar 14, 2002 | 11:01 AM
acurism's Avatar
New User
Default Re: can u get 190whp off of 1.8L? (junglistgsr)
JDM GSR has B18C on the block!!
US GSR has B18C1 on the block!!!
I should know, i have a jdm gsr motor!!!
The jdm gsr motor is rated at 178 hp, vs the us spec rated at 170 hp.
Old Mar 14, 2002 | 01:36 PM
GQ 05YellowEVO8's Avatar
Default Re: can u get 190whp off of 1.8L? (acurism)
I have on a bone stock GSR bottom end and DPR headwork.
with finer tuning I'm majking like 192-193 WHP, but confirmed I'm making 188.5 WHP corrected on the dyno.
Old Mar 14, 2002 | 03:47 PM
Some Gook with a DC2's Avatar
Default Re: can u get 190whp off of 1.8L? (VTEC-MAN95GSR)
the jdm b18c's mke more hp than usdm versions because of the ecu and the use of higher octane available over there.
Old Mar 14, 2002 | 04:45 PM
JCushing's Avatar
wow all you have to do to get 190whp is put in a itr crank, ctr pistons and a ctr head! man i wish i bought a gsr instead... (hope the sarcasm is noticed). im not talkin **** about any model all im sayin is that 190whp is a 40hp gain and its hard to do that with stock internals..... unless its turboed
Old Mar 14, 2002 | 05:19 PM
rodimus's Avatar
Default Re: can u get 190whp off of 1.8L? (JCushing)
not hard...just expensive
Old Mar 14, 2002 | 06:37 PM
Spyderwebab's Avatar
You won't hit 190whp, unless it is forced induction, without upgrading the internals, ie. cams & pistons.
Considering I made 175whp w/ my signature.
Old Mar 14, 2002 | 08:17 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: can u get 190whp off of 1.8L? (Spyderwebab)
I made 154 with i/h/e with my GSR hatchback. Those were DC headers, and broken (aka homemade shortram) AEM and 2.5" straightpipe with crap muffler. I believe you can make 189 and up, Just get that compression 11.1. Then mod it...see where you go and compare the charts to stock GSR bottom ends.
Spydey...Greer replaced the staging and timing lights! It was a Great night out there tonight! Email me about the ATL meet.
Old Mar 14, 2002 | 09:56 PM
t's Avatar
t
It has been done a couple of times without forced induction, using stock honda parts.
Old Mar 14, 2002 | 11:40 PM
ARunto's Avatar
Default Re: can u get 190whp off of 1.8L? (t)
My old setup:
B18C Block
CTR Pistons
ITR Head (Stock)
Jun Valve Springs w/ Crower Retainers
Toda Spec C's
JDM 4-1
Test Pipe
ITR Exhaust
P28 with Skunk 2 Chip
My setup now:
LS/VTEC
US ITR pistons
B16A Head
JDM 4-1
Hondata Stage 2
-Alan
Old Mar 15, 2002 | 03:19 AM
Black SVT's Avatar
Default Re: can u get 190whp off of 1.8L? (ARunto)
Kenji on this board makes 204 in his ITR it is still 1.8 and N/A.It can be done and has been many times.Those of you that think FI is a must to make that # with 1800cc's are lost.
Old Mar 15, 2002 | 04:21 AM
kenji's Avatar
Default Re: can u get 190whp off of 1.8L? (Dc2k-specR)
Roger,
Actually, I only made 196 Hp and 130 lbs-ft on my ITR. Stock head and stock block. Mugen head gasket and all of the other normal NA mods. Nothing special.
204 Hp would be real nice though
-kenji
Old Mar 15, 2002 | 05:18 AM
redteg1's Avatar
yea 200 would be nice
[Modified by redteg1, 2:19 PM 3/15/2002]
Old Mar 15, 2002 | 05:34 AM
D.Lansing's Avatar
Default Re: can u get 190whp off of 1.8L? (redteg1)
I think the guy's original question was can 190whp be reached with all honda parts, including type R cams. I think this is possible, but you will need REALLY good headwork and tuning. Not probable, but possible, I think Ive seen this done before.
Old Mar 15, 2002 | 05:52 AM
Westrock2000's Avatar
Default Re: can u get 190whp off of 1.8L? (D.Lansing)
190 off a 1.8 B18B...that would be nice. Ahh I'll stick with my goal off ~165
