FS:SPEC stage 5 clutch and aluminum flywheel
SPEC stage 5 clutch and aluminum flywheel for sale.clutch will hold 575fwt and only has passes from two events,probably less than ten.has been 136mph in my new car,but i am about to step it up and need a twin disc.sells for $808 new,will let go for $450.wear marks are normal on a clutch this aggresive.when taking pics i discoverd that the disc had a bad spot in it,so it will come with a new disc.i might could even substitute for a stage 3 disc if you want.it should last at least one full season on a hgigh hp car.
Modified by turbotypeR at 2:56 PM 12/2/2005
Modified by turbotypeR at 3:00 PM 12/2/2005
reset2k
Apr 12, 2006 05:15 PM
