DA Motor Mount
Old Dec 1, 2005 | 11:18 PM
Chilly61383's Avatar
Default DA Motor Mount
I have a 93 DA. And the Drivers side mount on the block, the 2 prongs, werent there when I got the car. So I picked up one on ebay. The guy finally got back to me and said its off a 94-01 teg. Will that still work with a DA? If not can I use the mount from an eg or 94-01 teg instead(the mount with the ruber inside) of the one from the DA?
Old Dec 2, 2005 | 01:40 AM
SlamminS85's Avatar
Default Re: DA Motor Mount (Chilly61383)
i dont know but send me a PM when you find out
Old Dec 2, 2005 | 08:00 AM
Bump. Anyone?
Old Dec 2, 2005 | 11:03 AM
Nobody? Common some has to know. Dont let me wast my money again without me knowing.
Old Dec 2, 2005 | 06:31 PM
Bump, someones got to know this.
Old Dec 3, 2005 | 11:31 AM
RaceCarRyne's Avatar
you have to use the mount that bolts to the block it self from a da.. because it has an off-set to it.. i tried using the other one from a 94 ls and it def didnt come close..
Old Dec 3, 2005 | 01:24 PM
Default Re: DA Motor Mount (DC2jdmIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2jdmIntegra &raquo;</TD></TR><TR><TD CLASS="quote">you have to use the mount that bolts to the block it self from a da.. because it has an off-set to it.. i tried using the other one from a 94 ls and it def didnt come close..</TD></TR></TABLE>
What if I used the mount that bolts to the chasis? Wouldnt that work?
Old Dec 4, 2005 | 12:07 AM
no because the studs them selvs are off set to fit in that mount.. actually i have a tranny mount back moutn and divers mound and post mount and im gonnna try to convert it over and see if that whole setup will work..
DB1_559
Jul 4, 2007 08:09 AM
hondachris1994
11
Nov 25, 2006 05:52 AM
B18civic5g
Jan 8, 2005 12:54 PM
lazynok
Dec 29, 2004 06:04 AM
