Sanding Tips?
Old Dec 1, 2005 | 07:32 PM
JRizEJ6's Avatar
Default Sanding Tips?
im looking for tips on the proper way to sand something to get it ready for paint. ill be sanding my rear lip and i dont know where to start? what grits do i use and in what order?
Old Dec 1, 2005 | 07:36 PM
Russ713's Avatar
dAng!
Default Re: Sanding Tips? (JRizEJ6)
you'll start with the heavier sanding paper and work your way to the finer paper. If you're going to use regular sand paper like most, be sure to rub with the base of your palm and NOT your fingers. Sanding with your fingers will unintentionally cause you to make waves in the plastic from where your fingers put uneven pressure as you rub the sand paper back and forth.
Old Dec 1, 2005 | 07:40 PM
JRizEJ6's Avatar
Default Re: Sanding Tips? (Russ713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Russ713 &raquo;</TD></TR><TR><TD CLASS="quote">you'll start with the heavier sanding paper and work your way to the finer paper. If you're going to use regular sand paper like most, be sure to rub with the base of your palm and NOT your fingers. Sanding with your fingers will unintentionally cause you to make waves in the plastic from where your fingers put uneven pressure as you rub the sand paper back and forth.</TD></TR></TABLE>
how many variations of grit will or should i go through? could i just buy like a mixed pack of sand paper?
Old Dec 1, 2005 | 08:14 PM
JRizEJ6's Avatar
Default Re: Sanding Tips? (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">320, 400, 600, 800, 1000, then wetsand with 1500</TD></TR></TABLE>
thanks
Old Dec 1, 2005 | 09:00 PM
DiRT!'s Avatar
to make it easier use a sanding block
oh and to wetsand do 1200 1500 and finish with 3000.
Old Dec 1, 2005 | 09:53 PM
JRizEJ6's Avatar
Default Re: Sanding Tips? (DiRT!)
k whats wetsanding? just sanding w/water?
Old Dec 1, 2005 | 09:56 PM
PrinceAli132's Avatar
yup
Old Dec 2, 2005 | 09:19 AM
zccr-xsi's Avatar
well if u want to buff it to make it shiny u wet sand.when i painted my car i sanded it with 150 then again with 180.if u want it true i would do i all by hand or blck it out cause a d.a can cut grooves in it if u dont hold it flat.some advice if u paint it black like i did u better make sure every bit of body work is right or it will show.remeber black dont hide **** it shows every lil mistake in bodywork that is there.
Old Dec 2, 2005 | 11:48 AM
ezza's Avatar
Default Re: (vteckillenzc)
paint your whole car white then you will never have to worry about dents
iv always found making sure the can and the surface your spraying is at a toasty temperature, worth using a heat gun if its cold where your spraying
Old Dec 2, 2005 | 02:06 PM
zccr-xsi's Avatar
Default Re: (ezza)
damn i wish i did paint it white now.but im happy with the finish its not a half as job it was done right.just wish i did it in diff. color like silver.btw black nasty color hard to keep clean.
Old Dec 2, 2005 | 02:21 PM
civicaleg's Avatar
Using all those different grit papers just wastes time and do not help the overall end result.
So many people give advise that don't mean ****.
All You have to do is sand the part with some 400-600 grit paper. then clean, then paint. If you want to make it smoother after painting then you can sand with 1000-3000 then polish for a nice gloss.
Old Dec 2, 2005 | 04:15 PM
zccr-xsi's Avatar
Default Re: Sanding Tips? (civicaleg)
damn doesnt anyone know what a buffer is anymore. man hand sand it with 1200 and buff it out.u dont want to sand with all them diff grits cause when u buff ull burn right though the paint.once u do that your screwed ull be spotting in that area.
Old Dec 2, 2005 | 04:20 PM
Tad's Avatar
Tad
Default Re: Sanding Tips? (vteckillenzc)
So all this wetsand talk,
it confuses me.
Won't that polish the surface to a gloss if you go all the way up to 1500, or even 3000 like mentioned?
isn't he just talking about prepping for paint?
So wouldnt that be too slick of a surface for the paint?
I thought the wetsanding process was for AFTER it's been painted.
So can we clear that up?
what are the sanding/sandpaper steps needed for PREP before paint?
Old Dec 2, 2005 | 04:31 PM
whoa its len 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRizEJ6 &raquo;</TD></TR><TR><TD CLASS="quote">im looking for tips on the proper way to sand something to get it ready for paint. ill be sanding my rear lip and i dont know where to start? what grits do i use and in what order?</TD></TR></TABLE>
Basic steps I use...
-wetsand surface with 400-600
-prime
-wetsand primer with 1000
-basecoat
-*optional wetsand with 2000 for imperfections and lay down another basecoat
-clearcoat
-light wetsand clearcoat with 2000
-light buff with 3M rubbing compound
-wax and shine
Sometimes Ill change up to a more finer grit or sand inbetween coats. Depends on the job I do. But thats your basic steps for an average paint job.
Old Dec 2, 2005 | 04:37 PM
Default Re: Sanding Tips? (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">what are the sanding/sandpaper steps needed for PREP before paint?</TD></TR></TABLE>
Before paint, since hes doing his rear lip heres what I usually do...
-clean/sand out imperfections with 400/600 or rougher depending on the condition of the lip
-if there big dents or gashes I use kitty hair bondo to smooth out the surface (kitty hair is usually the blue green bondo with fiberglass in it)
-wetsand surface with 400/600 till smooth
-prime surface
-wetsand surface with 1000 till smooth
-repeat until your happy
-start laying down your base
Old Dec 2, 2005 | 05:04 PM
Tad's Avatar
Tad
ah, ok cool thanks, that clears up alot
(ima do the sanding on my rear bumper/tailgate
to save money on paint cost).
So u would recommend any type of sanding block imparticular? or just hands?
Old Dec 2, 2005 | 05:35 PM
zccr-xsi's Avatar
i would say use 180, if its in really good shape u might u might be able to use 220.
i sanded mine with 180 then shot an epoxy primer on it the sanded it with 220 and primed and again,dont forget dont oil the d.a before u sand cause it will spit out lil bit of oil on your car.and if u dont wipe it down with a grease and wax remover(u wipe it on then wipe it off before it drys,it gets all the oils,waxes and drit off it.)if u dont 50% chance the paint will fish eye.
Old Dec 2, 2005 | 05:39 PM
civicaleg's Avatar
These people are so confusing. No one really knows what they are talking about. I think i will be leaving HT forever. So so Gay now!!!!
Old Dec 2, 2005 | 05:40 PM
civicaleg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicaleg &raquo;</TD></TR><TR><TD CLASS="quote">These people are so confusing. No one really knows what they are talking about. I think i will be leaving HT forever. So so Gay now!!!! </TD></TR></TABLE>
Just look on http://www.autobody101.com
ek4shizzle
Paint and Body
Dec 7, 2007 01:06 PM
pos_cd5
May 18, 2006 10:50 PM
TRN
Jul 15, 2005 09:32 AM
SleekBlkPrelude
Jul 17, 2003 03:29 PM
drkblue_civic
Sep 13, 2002 03:45 PM
