My brand of oil !
Old Dec 1, 2005 | 04:51 PM
jdmoutlaw's Avatar
Default My brand of oil !
I know this is a big topic in all motor but I wanted to share with everyone.
I work at a boat dealer so Its easy for me to get.
Yamalube 4- M FC-W
High levels of bearing protection, far more than automotive oil.
High resistance to foaming under high rpm.
Superior lubrication even when fuel dilltion is present.
Far superior rust and corrosion protection.
I wanted to share this with everyone to help get more life out of your motors
to have better racing!
Old Dec 1, 2005 | 05:28 PM
SpeedDreamz.com's Avatar
Default Re: My brand of oil ! (jdmoutlaw)
HOw much is a qt?
Old Dec 1, 2005 | 05:35 PM
Robb's Avatar
Default Re: My brand of oil ! (SpeedDreamz.com)
Honda has an equlivilent. Honda GN4 10w40 sold at Honda Powersport dealers.
Old Dec 1, 2005 | 05:38 PM
IT'S ME DAVID's Avatar
NooB
so you use this in your allmotor car as well or your just recemending this but never tried this.
Old Dec 1, 2005 | 05:40 PM
hondaguyef's Avatar
Default Re: My brand of oil ! (K SERIES)
You run this oil in your Motors Richie? What weights is it available in? Price?
Phil
Old Dec 1, 2005 | 05:54 PM
jdmoutlaw's Avatar
Default Re: My brand of oil ! (hondaguyef)
Yes this is the oil I use in my motors.
Price you may want to take out a loan! LOL Not real sure I don't pay for it, its high
You can get it in most popular wts ,I use 10-30
We get it in 55 gal drums also avl in qt and gal jugs
Old Dec 1, 2005 | 05:57 PM
jdmoutlaw's Avatar
Default Re: My brand of oil ! (Robb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robb &raquo;</TD></TR><TR><TD CLASS="quote">Honda has an equlivilent. Honda GN4 10w40 sold at Honda Powersport dealers.</TD></TR></TABLE>
We use to deal with honda to but the only thing worth getting from them is hondabond and there carb cleaning kit!
Old Dec 1, 2005 | 06:13 PM
EJtypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmoutlaw &raquo;</TD></TR><TR><TD CLASS="quote">I know this is a big topic in all motor but I wanted to share with everyone.
Yamalube 4- M FC-W
to have better racing!</TD></TR></TABLE>
HAHA...you belive this???? i work at GT Performance in montclair, CA. and yes it a boat shop. we build high end 500-1300hp motors. as well as a service shop. all we use is torco synth. blend or mobil 1 full synthetic. all that corroision resistance is crap. anything submerged in oil is corrosion guarded. and ALL oils foam. except for PS fluid which isnt an oil and if you have fuel leaking past your rings your screwed anyways. and yamalube is 2 stroke oil. unless you are referring to the 4 stroke oil. All that is, is Valvoline with a yamaha name.
Old Dec 1, 2005 | 08:31 PM
jdmcars.com's Avatar
Default Re: My brand of oil ! (EJtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJtypeR &raquo;</TD></TR><TR><TD CLASS="quote">
HAHA...you belive this???? i work at GT Performance in montclair, CA. and yes it a boat shop. we build high end 500-1300hp motors. as well as a service shop. all we use is torco synth. blend or mobil 1 full synthetic. all that corroision resistance is crap. anything submerged in oil is corrosion guarded. and ALL oils foam. except for PS fluid which isnt an oil and if you have fuel leaking past your rings your screwed anyways. and yamalube is 2 stroke oil. unless you are referring to the 4 stroke oil. All that is, is Valvoline with a yamaha name.</TD></TR></TABLE>
The 4-m stands for 4 stroke.
So if all oil is the same why use only Mobil 1 or Torco? You should just go get the no-name oil as it costs less!
Old Dec 2, 2005 | 04:13 AM
Turbo-charged's Avatar
Default Re: My brand of oil ! (jdmcars.com)
haha rob....a little off topic but when i was in norwalk ohio for the ndra finals i was in a gas station and found some oil....it was a black bottle with a wh ite lable...and all it said on it was "OIL" real big with "SAE 30" under it. no brand name or anything. it was awesome so i had to buy it just as decoration. on the back of the bottle it says "caution- this oil is not suitable for use in most gas powered engines built after 1963. use in modern engines may cause equipment harm"
best 2 dollars i ever spent!
Old Dec 2, 2005 | 04:32 AM
Default Re: My brand of oil ! (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">haha rob....a little off topic but when i was in norwalk ohio for the ndra finals i was in a gas station and found some oil....it was a black bottle with a wh ite lable...and all it said on it was "OIL" real big with "SAE 30" under it. no brand name or anything. it was awesome so i had to buy it just as decoration. on the back of the bottle it says "caution- this oil is not suitable for use in most gas powered engines built after 1963. use in modern engines may cause equipment harm"
best 2 dollars i ever spent!</TD></TR></TABLE>
Acutally, AutoZone sells something very similar. It comes with a Yellow sticker though, maybe it is an upgrade , and still have that same warning on it in small print on the back -I wonder how many people use that without even reading it. I think @ AutoZone it is about $0.79 or so.
Old Dec 2, 2005 | 04:33 AM
i'll have to check that out. this stuff reminded me of the **** you see in TV where somebody is drinking a can of "BEER". i was amazed how expensive this stuff was!
Old Dec 2, 2005 | 05:43 AM
99lspwr's Avatar
Yamalube 4- M FC-W
If I didnt pay for it, I would use it too!!!! (cant blame you there.. )... Its funny though oil is always such a heated debate..I work for an automotive dealer, and people are always talking about how superior synthetic oils are compared to conventional, blah,blah,etc,etc...My only argument is that I have been using conventional oil on a regular basis for the last 10 years in all the cars that I have owned, and never had any types of problems...Sorry, I am not trying to turn this in to an oil debate, I would use that **** too if it was free!!
Old Dec 2, 2005 | 07:30 AM
steve1320's Avatar
free oil ok but i'd prefer using torco for now...
Old Dec 2, 2005 | 07:31 AM
4piston's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i'll have to check that out. this stuff reminded me of the **** you see in TV where somebody is drinking a can of "BEER". i was amazed how expensive this stuff was!</TD></TR></TABLE>
Kroger used to sell Cost Cutter beer with only BEER on the label. I remember my grandpa drinking it when I was VERY young.
Old Dec 2, 2005 | 12:27 PM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com &raquo;</TD></TR><TR><TD CLASS="quote">
I use that autozone oil in my tranny so far no problems. And now it is 1.09 a qt.
Old Dec 2, 2005 | 12:31 PM
hondaguyef's Avatar
Default Re: My brand of oil ! (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
I use that autozone oil in my tranny so far no problems. </TD></TR></TABLE>
That's cause'you shift like a girl
Old Dec 2, 2005 | 01:28 PM
perhaps but I still cut better 60 foot times then you.
Old Dec 2, 2005 | 02:56 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">perhaps but I still cut better 60 foot times then you. </TD></TR></TABLE>
It's cause you were Mase'd Y0!!!!! I still go quicker than you on street tires w/ a bone stock longblock though
Old Dec 2, 2005 | 03:14 PM
11SEC CIV's Avatar
ok chad and phil...meet at atco and lets settle this
Old Dec 2, 2005 | 03:39 PM
.RTErnie's Avatar
Default Re: My brand of oil ! (12SEC CIV)
so bascially we can all go back to using Torco and Mobil1. glad we got that covered
btw Phil's car is faster...its that maaad tight Hella JDM vtak he's got.
Old Dec 2, 2005 | 03:47 PM
Dragline's Avatar
Yamalube 4- M FC-W
Everything you stated is true about boat oils, who ever said that automotive oil and boat oil is the same, that is wrong. Boats oils are designed to with stand way more thermal brake down the standard automotive oils, simply because boat engines are under constant load.
Old Dec 2, 2005 | 04:56 PM
doublej's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">haha rob....a little off topic but when i was in norwalk ohio for the ndra finals i was in a gas station and found some oil....it was a black bottle with a wh ite lable...and all it said on it was "OIL" real big with "SAE 30" under it. no brand name or anything. it was awesome so i had to buy it just as decoration. on the back of the bottle it says "caution- this oil is not suitable for use in most gas powered engines built after 1963. use in modern engines may cause equipment harm"</TD></TR></TABLE>
That's when a bottle of oil was mostly just oil. No API ratings, just Detergent or Non-detergent. I'm showing my age.
Old Dec 2, 2005 | 05:31 PM
EJtypeR's Avatar
Default Re: My brand of oil ! (doublej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">so bascially we can all go back to using Torco and Mobil1. glad we got that covered
btw Phil's car is faster...its that maaad tight Hella JDM vtak he's got.</TD></TR></TABLE>
im not saying thats all you can use, im just saying thats all we use. and regular kendal.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dragline &raquo;</TD></TR><TR><TD CLASS="quote">
Everything you stated is true about boat oils, who ever said that automotive oil and boat oil is the same, that is wrong. Boats oils are designed to with stand way more thermal brake down the standard automotive oils, simply because boat engines are under constant load.</TD></TR></TABLE>
how do you figure...?
Old Dec 2, 2005 | 05:39 PM
hondaguyef's Avatar
Default Re: My brand of oil ! (RTErnie)
You mean NON-Vtak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">so bascially we can all go back to using Torco and Mobil1.</TD></TR></TABLE>
Basically. I'm useless to this thread so, I'm staying out
Phil
