Broke a sensor which one is this? (pics inside)
Old Dec 1, 2005 | 04:34 PM
Dirtfall's Avatar
Default Broke a sensor which one is this? (pics inside)
Sory the pics are so shitty. They were takin with a webcam because thats all i have right now. The sensor was on the block below the intake manifold. The motor is a b16A2. Does anyone know which one it is or a part number. I looked on majestic honda's website and couldnt find it please help.
https://home.comcast.net/~dirt...1.jpg
https://home.comcast.net/~dirt...2.jpg
https://home.comcast.net/~dirt...3.jpg
https://home.comcast.net/~dirt...5.jpg
https://home.comcast.net/~dirt...6.jpg
https://home.comcast.net/~dirt...8.jpg
Modified by Dirtfall at 6:02 PM 12/1/2005
Old Dec 1, 2005 | 04:41 PM
Dirtfall's Avatar
Default Re: Broke a sensor which one is this? (Dirtfall)
I cant get the f'in pictures to work on the page so just go to the links
Old Dec 1, 2005 | 05:06 PM
HoOridin's Avatar
knock sensor
Old Dec 1, 2005 | 05:09 PM
Dirtfall's Avatar
Default Re: (HoOridin)
you know where i can buy one? or the part number?
Old Dec 1, 2005 | 05:46 PM
Dirtfall's Avatar
Default Re: (Dirtfall)
Nevermind i found the part number. Its 30530-PV1-A01 in case anyone cares.
Old Dec 1, 2005 | 08:38 PM
hayabusa160's Avatar
broke mines too same way. meh dont need it
Old Dec 2, 2005 | 01:37 PM
Mike@K-Tuned's Avatar
Default Re: (hayabusa160)
That is definately a knock sensor, and I think it is pretty expensive from what I've heard. What ECU are you running your B16A2 engine with? Alot of people (including myself) do not need to use that sensor if an OBD 1 ecu, like a P28 for example is being used.
Old Dec 2, 2005 | 02:10 PM
Dirtfall's Avatar
Default Re: (EGgsrAM)
Im using a chipped p28. So your saying i might not need to have this sensor at all? Would i throw a code without one?
Old Dec 2, 2005 | 02:35 PM
92Jspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirtfall &raquo;</TD></TR><TR><TD CLASS="quote">Im using a chipped p28. So your saying i might not need to have this sensor at all? Would i throw a code without one?
no you wont throw a code
Old Dec 3, 2005 | 06:22 AM
Dirtfall's Avatar
Default Re: (92Jspec)
sweet thanks guys you saved me alot of money for honda tech
Old Dec 3, 2005 | 08:46 AM
projectTeG's Avatar
whats your avatar?
Old Dec 4, 2005 | 10:33 AM
Default Re: (projectTeG)
Because a P28 ECU does not have pinouts for a knock sensor, it does not need to be wired up at all. Be careful not to break anymore sensors though, you need all of the others. JK , Good luck
Old Dec 6, 2005 | 04:46 AM
Dirtfall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">whats your avatar?</TD></TR></TABLE>
https://home.comcast.net/~dirt...r.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGgsrAM &raquo;</TD></TR><TR><TD CLASS="quote">Because a P28 ECU does not have pinouts for a knock sensor, it does not need to be wired up at all. Be careful not to break anymore sensors though, you need all of the others. JK , Good luck </TD></TR></TABLE>
Im just worried about remembering where everything goes because im putting in ctr pistons in my b16. Its my first time tearing into a motor. My blocks at the machine shop atm. Ill post pics of everything in a new thread after christmas sometime.
af97civic
May 30, 2004 11:42 PM
