POOR MANS TYPE R. CTR CAMS, CTR PISTONS. 100 OCATANE???
Old Dec 1, 2005 | 03:30 PM
MRCHUNDOESAY's Avatar
Default POOR MANS TYPE R. CTR CAMS, CTR PISTONS. 100 OCATANE???
I HAVE A GSR BLOCK ON TOP WITH A B16A HEAD WITH CTR CAMS AND CTR PISTONS.. WHAT IS THE COMPRESSION RATIO AND DO I NEED TO PUMP 100 OCTANE?
Old Dec 1, 2005 | 05:33 PM
dohcMONSTER's Avatar
Default Re: POOR MANS TYPE R. CTR CAMS, CTR PISTONS. 100 OCATANE??? (MRCHUNDOESAY)
no
Old Dec 1, 2005 | 05:45 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Why are you yelling at me?
You should be fine on pump gas, but tuning is very important when running such a high compression.
Old Dec 2, 2005 | 02:19 AM
thanks
Old Dec 2, 2005 | 02:24 AM
SlamminS85's Avatar
Default Re: (MRCHUNDOESAY)
yelling like that gives us the impression that your house is on fire and the only way to escape is to get your car working... that or your car is on fire and you are wondering why
Old Dec 2, 2005 | 09:00 PM
SlammedDC2's Avatar
Semper Fidelis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MRCHUNDOESAY &raquo;</TD></TR><TR><TD CLASS="quote">I HAVE A GSR BLOCK ON TOP WITH A B16A HEAD WITH CTR CAMS AND CTR PISTONS.. WHAT IS THE COMPRESSION RATIO AND DO I NEED TO PUMP 100 OCTANE? </TD></TR></TABLE>
Where are you getting 100 octane?
Old Dec 2, 2005 | 09:52 PM
JFG Kevin's Avatar
Default Re: POOR MANS TYPE R. CTR CAMS, CTR PISTONS. 100 OCATANE??? (BlackDC2_05)
You will be fine with 91 pump gas....i have CTR Piston on a GSR motor....so that will pull more compression then yours...and i'm doin good with 91... tuned...UNTUNE....was running really shitty till i put some octane booster...
knuckk
Dec 19, 2007 06:07 AM
lamboextreme
Nov 26, 2006 10:54 AM
duRritztiNy
35
May 16, 2003 10:36 PM
AllTDMnotJDM
12
Nov 13, 2002 09:52 PM
94gsr4d
Feb 4, 2002 02:53 PM
