CEL code 61, Primary o2 sensor question
The wiring on my primary o2 sensor is bad or something and it's gettting voltage irregularites. I'm getting a CEL code 61 and wonder if it's going to make me run rich or anything. The car seems to run fine and I don't get any other codes. Its too cold outside to be messing around with my car so i was wondering if it would cause any problems if i left it this way. I can fix it by messing with the o2 plug wiring and then resetting the ecu, but after a month or two the code would come back up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response</TD></TR></TABLE>
My 1997 dx has the same problem, cel61 after running for a few days after resesting ecu and cel coming back. Should i do a wire trace? Sensors are new and plugs are good shape........
vietnameseone
Jan 19, 2009 06:07 PM
undertheradar
Dec 4, 2004 08:03 AM
terminaloverlowd
10
Jul 27, 2004 03:12 PM
