help help help help help
Old Dec 1, 2005 | 02:08 PM
teamvirus's Avatar
My car breaks a lot!
Default help help help help help
ok so i have d16y8, im removing the wire harness but am having problems with a black thing!!! its right under the oil filter, how do i remove that?
Old Dec 1, 2005 | 02:09 PM
flood's Avatar
Default Re: help help help help help (teamvirus)
Title » Provide a brief description of your post.
You fail at teh interweb
sagron69's Avatar
post a picture becasue i have no idea what you're talking about.
Luserkid's Avatar
Is it a single wire? If so its your oil pressure sender. Just pull the top of the rubber piece and it should come off. If need be cut the base a little.
Old Dec 1, 2005 | 02:10 PM
teamvirus's Avatar
Default Re: help help help help help (Luserkid)
ya its a single wire, its hard and black
Old Dec 1, 2005 | 02:13 PM
teamvirus's Avatar
correction, its above the filter
Old Dec 1, 2005 | 02:27 PM
flood's Avatar
Isnt that the PCV valve? Plugs into the "black box"
Old Dec 1, 2005 | 02:43 PM
teamvirus's Avatar
This thing right there above the filter.
Old Dec 1, 2005 | 02:54 PM
Archidictus's Avatar
Unceasing Measure
That would be the oil pressure sending unit. Like has already been said, remove the rubber boot and pull the single-wire connection end off the sensor.
This is not rocket science.
Old Dec 1, 2005 | 02:58 PM
teamvirus's Avatar
Default Re: help help help help help (Archidictus)
i was just making sure, i didnt wanna break it
homesauce
Jun 1, 2006 10:02 PM
projsectEF
16
May 22, 2006 04:19 PM
OldSchoolHatch
Apr 3, 2003 05:03 AM
HondaCutter
Sep 14, 2002 08:26 PM
HondaCutter
Sep 14, 2002 01:24 PM
