GEN 2 rear discs on a 91 si
Old Dec 1, 2005 | 12:07 PM
ys1civic's Avatar
Default GEN 2 rear discs on a 91 si
I have been looking into doing rear discs on my 91 si hatch. i have seen it done and have been told that 90-93 integra trailing arms bolt right up and so do crx rear discs. I come to believe that the crx arms will bolt right up due to it being a civic. yet my main question is will 90' integra trailing arms and e-brake cables bolt right up to my hatch, i already have them everything i will need. Got everything for free so i thought i'd try it out. Also is there anything i have to do to proportion the fliud from the master cylinder so i have about the same % braking power all around?" Thanks
Old Dec 1, 2005 | 01:46 PM
CRXBart's Avatar
Default Re: GEN 2 rear discs on a 91 si (ys1civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ys1civic &raquo;</TD></TR><TR><TD CLASS="quote">I have been looking into doing rear discs on my 91 si hatch. i have seen it done and have been told that 90-93 integra trailing arms bolt right up and so do crx rear discs. I come to believe that the crx arms will bolt right up due to it being a civic. yet my main question is will 90' integra trailing arms and e-brake cables bolt right up to my hatch, i already have them everything i will need. Got everything for free so i thought i'd try it out. Also is there anything i have to do to proportion the fliud from the master cylinder so i have about the same % braking power all around?" Thanks </TD></TR></TABLE>
Yes they will I had 90-93 teg rear disc on my 90 Hatch, the cables and lines fit right up. People say that you need a different prop. valve but I always just used a stocker. I also did the conversion on my 89 CRX Si, with lude/ accord wagon 11.1" fronts, w/ stock prop valve. It works great, the only problem I see is when you use such a large setup on the front then you need an 90-91ex MC. The prop valves never seemed to matter to me, they always stopped great for me.
daluv
21
Dec 3, 2008 04:43 PM
classciv
Nov 25, 2007 04:16 PM
wizzards581
13
May 16, 2004 08:11 AM
onesikcivic
Dec 19, 2003 09:28 AM
Sleeper Sii
Sep 15, 2002 03:44 PM
