How do you test spark plug wires to see if they still are working properly?
Old Mar 13, 2002 | 07:47 PM
Volcom's Avatar
Default How do you test spark plug wires to see if they still are working properly?
I've got a multimeter. Do I send a current though them? I have a 94 RS and it has orignal wires. I checked into new OEM wires at the dealer and they wanted 61 bucks. Can I get them cheaper than that?
Thanks for the help.
I posted this in here since the type-r guys and girls seem to know more than the regular integra forum.
Old Mar 13, 2002 | 08:03 PM
Warren's Avatar
Wrong-Way Wang
Default Re: How do you test spark plug wires to see if they still are working properly? (Alphanumeric)
Call up (username) Mike K @ Naples Acura. He'll cut you a big discount. I think you get the cap, rotor, and wires for $59.
Warren
Old Mar 13, 2002 | 08:09 PM
Renegade's Avatar
Default Re: How do you test spark plug wires to see if they still are working properly? (Warren)
I was at Kragens last week and saw a spark plug wire tester.
Old Mar 13, 2002 | 08:14 PM
PiYoImuT's Avatar
Default Re: How do you test spark plug wires to see if they still are working properly? (98401R)
hmm... how to test them...
put one in your mouth and put the other end to a battery..
HeHeHe..
(sorry, I just have to post this since I am getting nuts)
Old Mar 13, 2002 | 10:48 PM
Louie's Avatar
What would Chente do?
Default Re: How do you test spark plug wires to see if they still are working properly? (PiYoImuT)
1st, you will need a "friend".
2nd, a small metal rod.
Proceed by disconnecting plug wires. Next pick a wire and push metal rod into the end of it. Have your friend hold this rod as you crank the engine over. Observe said friend doing the chicken dance. Repeat for remaining cylinders.
Old Mar 14, 2002 | 12:41 AM
brinks's Avatar
No current is required. Measure the resistance on the wires, resistance should be 25,000 ohms max at room temperature, if they are out of spec, replace them.
Old Mar 14, 2002 | 06:20 AM
Renegade's Avatar
Default Re: How do you test spark plug wires to see if they still are working properly? (brinks)
Finally someboady that knows what they are doing.
I still like vago ITRs idea better, why don't try that one first and make you have a camera handy.
LordAphotic
Sep 22, 2010 12:04 PM
lsvtechatchy
May 13, 2010 09:26 AM
jsrusse11
10
Nov 7, 2005 05:20 PM
Eluzion
Apr 19, 2004 11:14 AM
EzKV
Mar 17, 2004 01:56 PM
