Question about Fujitsubo Exhaust
Old Dec 1, 2005 | 11:06 AM
ans's Avatar
ans
Default Question about Fujitsubo Exhaust
In order for the RM-01A to fit on USDM itr, would both the stock cat and header need to be changed to JDM cat and header? Or can the stock header be left alone and just changing the stock cat to JDM cat? Thanks!
Old Dec 1, 2005 | 11:23 AM
Kendall's Avatar
You can use the stock cat actually.
Old Dec 1, 2005 | 11:58 AM
ITR3189's Avatar
Default Re: (Kendall)
Isnt the stock usdm cat to long since the RM01A is made for a jdm R ?
Old Dec 1, 2005 | 12:18 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You can use the stock cat actually.</TD></TR></TABLE>
You need a shorter cat because the Fuji B-Pipe is longer. That is, if you are using a jdm header. If you are using a US sized header, I have no idea.
Old Dec 1, 2005 | 12:27 PM
Opie's Avatar
FWIW I run the Fuji exhaust with a Toda header and JDM cat
And FWIW if you are blingin so heavy on the tail end you need to be equally blingful on the header end
Old Dec 1, 2005 | 04:16 PM
thk's Avatar
thk
Members Only
Default Re: (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">You need a shorter cat because the Fuji B-Pipe is longer. That is, if you are using a jdm header. If you are using a US sized header, I have no idea.</TD></TR></TABLE>
I'm going to take a wild guess and state that it's all in the cat length. I think header length is same from US/JDM but the cat length is where the problem lies.
But I've been forgetting all my useless ITR trivia knowledge ever since I got rid of mine.
Old Dec 1, 2005 | 04:47 PM
ans's Avatar
ans
Default Re: Question about Fujitsubo Exhaust (ans)
So all I need is just a JDM cat and leave the stock header alone? Where can I get a hold of a JDM cat?
Old Dec 1, 2005 | 04:50 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ans &raquo;</TD></TR><TR><TD CLASS="quote">So all I need is just a JDM cat and leave the stock header alone? Where can I get a hold of a JDM cat?</TD></TR></TABLE>
its not that simple, the jdm cat will fit your setup length wise but its made for a JDM header with a 2.5in collector...your usdm header is only 2.25in
you will need a custom 12in cat to fit your current setup or cut the fuji or buy a JDM header
Old Dec 1, 2005 | 06:07 PM
97 TYPE-R 312's Avatar
Default Re: Question about Fujitsubo Exhaust (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">You will need a custom 12in cat to fit your current setup or cut the fuji or buy a JDM header </TD></TR></TABLE>
Just don't cut the FujiBLINGsuboness!
-Victor
Old Dec 1, 2005 | 06:10 PM
BlueR's Avatar
Default Re: Question about Fujitsubo Exhaust (97 TYPE-R 312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 &raquo;</TD></TR><TR><TD CLASS="quote">Just don't cut the FujiBLINGsuboness!
-Victor</TD></TR></TABLE>
ooooops, too late
Old Dec 1, 2005 | 06:12 PM
jetydosa's Avatar
25 Year Member
I got a JDM cat FS that will work, send me a PM.
Old Dec 1, 2005 | 06:14 PM
BlueR's Avatar
Default Re: Question about Fujitsubo Exhaust (jetydosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">I got a JDM cat FS that will work, send me a PM. </TD></TR></TABLE>
i hate to butt in again but i don't want him to get the wrong impression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">its not that simple, the jdm cat will fit your setup length wise but its made for a JDM header with a 2.5in collector...your usdm header is only 2.25in
if he buys a jdm cat, he also gonna have to buy a jdm header
Old Dec 1, 2005 | 06:27 PM
jetydosa's Avatar
25 Year Member
Oh, I misread. Yes to clarify to use JDM cat you will need JDM length header also (JDM 4-1, Toda, Spoon etc)
Kusai.Nihonjin.Desu
Feb 24, 2006 07:01 PM
98itr0448
Sep 1, 2004 05:28 PM
ChopstiX
Oct 29, 2003 09:23 AM
98cwitr
Dec 15, 2002 11:34 PM
brownman72000
Jul 10, 2002 04:11 PM
