coolant fan
Old Dec 1, 2005 | 10:45 AM
b_serious's Avatar
Default coolant fan
it isnt turning on.. the cars temp is normal its about 75degrees outside but the fans wont come on.. i didnt think anything of it cause the temp gauge is reading normal.. any input? i let it sit for about 30 min watching it and it doesnt turn on
Old Dec 1, 2005 | 11:02 AM
Kendall's Avatar
It won't turn on until it needs to turn on. If it doesn't turn on, then it doesn't need to turn on. In the winter I usually just do away with the fan completely.
Old Dec 1, 2005 | 01:04 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">It won't turn on until it needs to turn on. If it doesn't turn on, then it doesn't need to turn on. In the winter I usually just do away with the fan completely.</TD></TR></TABLE>
I agree as well. As per your other thread about the thermostat, as long as the coolant level drops, your thermostat is opening, and you refill the coolant, then you're good to go.
Especially with the colder temperatures now, the fans rarely turn on unless you're sitting in traffic in hot weather with the A/C on, or under heavy load during driving. If your temps stay good, then I wouldn't worry about the fans. They should turn on when they need to.
walrus_07
Feb 21, 2009 10:16 PM
dth0ng69
Jan 28, 2009 06:19 AM
sony224422
Aug 20, 2006 09:47 AM
kinvid22
Dec 15, 2003 10:49 PM
vtec69
Jan 16, 2003 08:06 AM
