Honda S2000 Honda S2000
S2000 tranny fluid
Old Dec 1, 2005 | 07:14 AM
jdm93cx's Avatar
Default S2000 tranny fluid
Im going to change my tranny fluid. I was going to buy it from Honda. But can you guys recommend anything better.
Old Dec 1, 2005 | 07:24 AM
papa5murf's Avatar
Default Re: S2000 tranny fluid (jdm93cx)
GM syncromesh
Old Dec 1, 2005 | 07:25 AM
Nishant's Avatar
Default Re: S2000 tranny fluid (03s2kblue)
^ thats what I use
http://www.hardtopguy.com sells it
GM Syncromesh FM
Modified by Nishant at 7:17 PM 12/8/2005
Old Dec 1, 2005 | 07:26 AM
jdm93cx's Avatar
Default Re: S2000 tranny fluid (Nishant)
Thanks!!!
Old Dec 1, 2005 | 07:47 AM
S2K K1DD's Avatar
jdm93cx get back to work damit lol sike na..... what about the diff what do you guys suggest for that
Old Dec 1, 2005 | 07:54 AM
Mr. Projekt's Avatar
* B A N N E D *
Royal Purple Synchromax for the tranny feels a bit better than GM Synchromesh even, and I use the RP for the rear end also.
Old Dec 1, 2005 | 08:35 AM
jdm93cx's Avatar
Default Re: S2000 tranny fluid (Slideways2000)
Thanks sideways.. (going with the royal purple)
Old Dec 1, 2005 | 08:59 AM
p nut's Avatar
Rockin' da HMTF, y0!
Old Dec 1, 2005 | 09:06 AM
WowOzYouRock's Avatar
Default Re: (P Nut)
^^ same here HMTF
Old Dec 2, 2005 | 05:55 AM
jolt-tsp's Avatar
Default Re: (Y2K_S2K)
I'll never understand tranny fluid. I used GMSMFM and it seemed to make the tranny a bit more smooth. My friend used GMFMSM on his teg though and after a track event, changed it and it was like water. So I don't know. I'd like to use that Royal Purple stuff and see how that goes. Also I've never really heard anything bad about Redline MTF once it warms up (supposedly it can be clunky when cold).
From my experiance -
Pennzoil 10w30 = Meh
Honda MTF = OK
GM Synchromesh = OK
GM Synchromesh FM = Pretty Good
Old Dec 2, 2005 | 05:59 AM
papa5murf's Avatar
Default Re: (jolt-tsp)
i also want to try the redline.... the clunkyness.. well.... pretty much all tranny fluids are clunky when cold...
Old Dec 2, 2005 | 06:27 AM
GDM Ap1's Avatar
Default Re: (
royal purple is Great IMO I changed it in my diff and made the car feel so much smoother im proboably going to do my tranny this afternoon at work
Old Dec 2, 2005 | 09:37 AM
sebringsilvers2k's Avatar
honda all the way
Old Dec 5, 2005 | 07:34 PM
WRS2K's Avatar
Half redline mtf, half honda MTF. Done.
Old Dec 5, 2005 | 07:56 PM
timg's Avatar
GM Synchromesh Friction Modified
I'm running it and it's great. This is NOT the same as normal GM Synchromesh- I DO NOT recommend normal GM Synchromesh.
Tim
Old Dec 8, 2005 | 05:49 AM
jdm93cx's Avatar
Thanks everyone... Going with the royal purple in the Trans and the Diff..
Old Dec 8, 2005 | 02:55 PM
p nut's Avatar
My BMW mechanic says that RP is all he uses and will not use anything else on the cars he works on and his personal cars. Maybe I'll give RP a shot next time.
Old Dec 8, 2005 | 05:29 PM
* B A N N E D *
Default Re: (P Nut)
It's a good mod for $80.
Old Dec 8, 2005 | 05:38 PM
timg's Avatar
Since when is oil a mod?!
I can think of much better things for $80!
Tim
Old Dec 8, 2005 | 08:56 PM
* B A N N E D *
Default Re: (timg)
I consider it a mod if it makes the driving feel better. Its not just oil either; I swapped tranny and diff fluid too.
phateless
Jun 23, 2009 10:39 AM
jdmCivic925
Mar 10, 2004 11:06 AM
TypeRuz
Oct 28, 2003 04:58 PM
P1mpSlap
Mar 15, 2003 03:28 PM
EF-9SiR
10
Nov 3, 2002 07:57 AM
