OBD0 ->OBD1 Distributor harness question
Old Dec 1, 2005 | 04:56 AM
Dancing is Forbidden's Avatar
Default OBD0 ->OBD1 Distributor harness question
I am making a jumper harness as to not chop up my engine harness. I matched everything up color to color, but on the OBD0 harness there are two white wires (it said something online about one being bigger than the other, but they are the same size). 2 & 7 in the OBD0 plug picture are the two wires in question. On the OBD-1 plug I have a white wire and a yellow/green wire left. Which one goes to which? Thanks a lot!
Old Dec 1, 2005 | 07:08 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: OBD0 ->OBD1 Distributor harness question (ih8jdm)
There are 2 white wires one is within the group of other wires and the other white wire is on the out side of the wires. Treat the outside wire as seperate as the instructions will not group one of the white wires, there is no large white wire. The outside white wire will go to the ICM which obd0 on obd1 its Yellow/Green...
Old Dec 1, 2005 | 08:36 AM
Rywire's Avatar
Default Re: OBD0 ->OBD1 Distributor harness question (ExplicitSpeed360)
correct, correct so 7-1 and 2-6
Old Dec 1, 2005 | 09:14 AM
Default Re: OBD0 ->OBD1 Distributor harness question (droppedcrxsi)
Thanks guys! Im about to go install it. I was sitting here with two helms pulling my hairs out!! HAHA.
civic46
May 24, 2007 11:08 PM
95_red_dc
Jan 10, 2007 08:22 AM
PA MATT
Oct 29, 2005 10:41 PM
BoRiCuA
18
Jun 21, 2004 12:15 PM
turbotime.
Jun 7, 2003 11:09 AM
