b18 dizzy into b16, possible?
Old Dec 1, 2005 | 04:54 AM
nautica_t's Avatar
Default b18 dizzy into b16, possible?
hey is it posible to put a b18 dizzy from a 93 LS which is obd0 and put that into a 1st gen b16 with obd0 dizzy?
so can i use a non-vtec dizzy into a vtec dizzy or are they teh same thing.
TIA, my dizzy went.
Old Dec 1, 2005 | 05:58 AM
crxnj's Avatar
Default Re: b18 dizzy into b16, possible? (nautica_t)
If the distributor is from a 93 then it's obd1..But it does line up,,you just have to cut one of the legs..
Old Dec 1, 2005 | 06:17 AM
nautica_t's Avatar
Default Re: b18 dizzy into b16, possible? (Mr.speaker)
but can i use a non-vtec dizzy on a vtec motor??
cuz i was reading and it said you can use the parts to rebuild.
Old Dec 1, 2005 | 08:03 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
In an emergency,we used a D16a6 distributor in a B16..
[We had to hack it all up but it did work..]
I found a bearing at NAPA #6001-2ZJ and replaced it
based on instructions found here: http://www.angelfire.com/ca/Dr....html
and http://www3.honda-perf.org/com...r.htm
fatbois88ef
Dec 4, 2011 02:23 PM
E_F_9
Oct 1, 2006 12:55 PM
crxkidb16t
Oct 12, 2005 11:19 AM
