need some help with poorman type r buildup!!! HELP. PLEASE
i have a stock obd-1 b18c1 block. im putting on a 92 si-r b16 head with obd-0 distributor and p30 pistons. im stuck with building it at the moment. which head gasket do i use? im picking up a oem b16 head gasket and am wondering if it'll do for now. i want to reuse my stock p72 head studs with the stock p72 timing belt, injectors, fuel rail, and water pump. does anyone see anything that im not suppose to???? i also need the torque specs and some instructions on how to torque down the b16 head. if anyone can help me find a writeup or something, it would greatly be appreciated since i cant seem to find anything on hondatech. for the setup, will i need to run an oil feed line or is that just for ls/b20-vtecs? any information regarding this buildup will be greatly appreciated. and im on a budget and cant get ARP or other head studs. thanks
Modified by d_SUPAl1l at 1:26 PM 12/1/2005
Modified by d_SUPAl1l at 1:27 PM 12/1/2005
=ITRpoweredEK9=
Jan 23, 2006 12:25 PM
