Camshaft Recomendations
Old Nov 30, 2005 | 02:34 PM
broketuner-Sol_Si's Avatar
Default Camshaft Recomendations
I plan on building the head soon and have been told several times CTR cams are ok but many other cams are better. My car is a D.D.(and will stay so) if possible passing smog would be nice . What should I go with?
Old Nov 30, 2005 | 02:50 PM
92Jspec's Avatar
Default Re: Camshaft Recomendations (broketuner-egb16a)
what's your set up?
Old Dec 1, 2005 | 07:26 AM
Well currently the only real mods are intake/exhaust (header soon) and exedy clutch/flywheel. I plan on doing something like CTR pistons balancing the bottom end, and decking the block and up top a mild P&P, valvetrain and cams. I'll most likely get the hondata s100 or 200 as far as an engine management system goes.
Old Dec 1, 2005 | 08:59 AM
CLMTFabEG6's Avatar
I havent used them personally, but ive read alot of good things about rocket motorsports cams
Old Dec 1, 2005 | 09:08 AM
92Jspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">Well currently the only real mods are intake/exhaust (header soon) and exedy clutch/flywheel. I plan on doing something like CTR pistons balancing the bottom end, and decking the block and up top a mild P&P, valvetrain and cams. I'll most likely get the hondata s100 or 200 as far as an engine management system goes. </TD></TR></TABLE>
CTR's will compliment your basic bolt-ons you have now. you will definately feel a difference when vtec kicks in. you can tell right off the bat how much more aggressive the CTR vs. B16a cams. just my .02 cents bro.... but good luck
Old Dec 1, 2005 | 09:33 AM
OH_SNAP10k_SHIFT!'s Avatar
i got skunk2 stage2s. i need something more aggressive tho.
JDM_Frijoles
Apr 20, 2007 11:27 AM
midnitesol
Mar 11, 2007 05:46 PM
mugenDA9 lover
Mar 1, 2007 03:39 PM
BLK99VTECR
Jul 7, 2005 12:24 AM
riceball777
May 5, 2003 12:38 AM
