wiring B16 into EF hatch. HELP!
so ive been reading about how to do the wiring. the only thing i dont know is....
how do you put the wires into the plugs? the other wires have those female style metal clips. do you use those? if so what size and are they dealer only? need help ASAP! thank you!
fuse box from civic:
fuse box from b16:
do we need do use the fuse box that came with the b16? or can we use the one that originally was in the car? they do look different. where the 3 prong connector (bottom right on fuse box, but its not connect on the civic.) And the civic one has the white wire with red stripe. but the b16 box as you can see has the white wire with red stripe going to another connector on the box? a little help..
fuse box from b16:
You can use the Civic's old fuse box. Reuse the white 4 pin connector already wired to the car, and ignore the three pin connector. It is for the Electronic Load Detector, and is not used on the B16
which is the 4 pin and which is the 3pin? do i re use the one on the bottom right that has the 3 holes for screws?
that has the 3 wires going into it?
can someone take a pic of their fusebox on a b16 please?
http://www.rywire.com
I think it is droppedcrxsi on this board, they helped me with all my wiring issues....
zero-one
Aug 9, 2005 03:02 PM
