Suspension & Brakes Theory, alignment, spring rates....
Recommendation on lug nuts??
Old Nov 30, 2005 | 12:32 PM
RalliartRsX's Avatar
Default Recommendation on lug nuts??
Well I have a set of wheels and I wanted to see some recommendation and experience some of you folks have had with various lug nuts. I heard some higher end lug nuts like Rays, because of weakness, will actually deform over time just by simply taking and putting back on. I also heard that the Muteki lugs, it seems the keys deform after a while and actually break.
But, my needs, well, weight is not "too" important. Bling, no. I really dont need the unwanted attention. I also will HAVE TO GET a WHEEL LOCK SET or something along those lines. So, when making a recommendation, I would also like to know some about wheel locks as well.
Thanks.
Old Nov 30, 2005 | 01:03 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Recommendation on lug nuts?? (RalliartRsX)
I've got Gorilla lugs & locks (chrome w/ closed ends). They have worked flawless for the past 6 years.
Those racing lugs will probably have durability problems in the long run because they are made to push the performance envelope. Since race teams have the equipent, money & knowledge to deal with any problems caused by using aluminum lugs, it's an easier trade off for the few grams of weight savings...
Old Nov 30, 2005 | 01:13 PM
Default Re: Recommendation on lug nuts?? (94eg!)
I would rather go with something like steel or something similarly strong to gain a few grams. I dont think it will be "that" noticable on the street. Plus, form over function is key (atleast to me anyways). I need something strong that will last.
What about these lug nuts??
http://estores.merchantpartner...282f
Old Nov 30, 2005 | 01:49 PM
94eg!'s Avatar
#1 Super Guy
Loved
Your link doesn't work unless you have an account..
Also, you wouldn't EVER notice any difference in performance no matter what. It's all a numbers game. One H-T member said he didn't even notice the slightest bit of difference when he switched from Rota Slipstreems over to Spoon SW-whatevers (several pounds difference each wheel)...
Old Nov 30, 2005 | 02:27 PM
broketuner-Sol_Si's Avatar
Whatever you do don't go with kyokugen(?). They seized on 7 of the 16 wheelstuds (yes antiseize was used!) and had to take it to a mechanic to get them off. most wheel locks I've dealt with are pretty much the same.
Old Nov 30, 2005 | 03:09 PM
Default Re: Recommendation on lug nuts?? (broketuner-egb16a)
If you look down a bit its the zenki ones
http://estores.merchantpartner...46_48
Well I would haver rather do wihtout the wheel lock, but I really would rather have it on.
Keep em coming guys. I might pick something up before the week is out
Old Nov 30, 2005 | 04:11 PM
Marauder's Avatar
I got a McGard spline drive locking kit. Needs two different keys to get all the lugs off. Worked great for me!
http://www.mcgard.com/search/d...ID=31
prostreetonline
14
Apr 29, 2005 01:02 PM
prostreetonline
Sep 13, 2004 10:58 PM
JPineda
May 17, 2004 06:00 PM
civicrights
Oct 16, 2003 05:48 PM
