help does a eg hatch have a fuel pump fuse;;;;; HELP;;;;;;
i just install a new pump it started just perfect untill i heard a pop and now it won't start getting spark but no more fuel
yes there is a fuse in the fuel pump power circuit, all though it supplies power to many other things as well. (gauges dead?)
15A, under dash fuse panel, far left or far right (depending on if you have SRS or not) in the row closer to the blinker relay.
find your wiring problem before replacing the fuse. it blew for a reason...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">it blew cause i was trying to start it like crazy </TD></TR></TABLE>
????????? huh?
fuses don't blow because you're turning over the engine a lot or acting crazy. only if there is too much current draw.
????????? huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">^^^ and the question you have to be asking yourself... did doing what ever you did damage anything else?</TD></TR></TABLE>
Yeah, recheck that pump wiring - there must be a short in there some where.
bigodub93
Sep 30, 2010 08:17 AM
5fingadiscount
Mar 27, 2008 04:25 PM
