Suspension & Brakes Theory, alignment, spring rates....
Best Shocks for a EK ?
Old Nov 30, 2005 | 09:17 AM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default Best Shocks for a EK ?
This is my first time posting in this fourm so ya, My friend has an EK and he wants to get some good suspension on his EK. Right now his looking for some shocks he has about a thousand dollors to spend. What would you guys recommend?
-thanks-armen-
Old Nov 30, 2005 | 10:03 AM
EK k kay's Avatar
Default Re: Best Shocks for a EK ? (Bone Stock)
Just shocks? Koni Yellows
Old Nov 30, 2005 | 12:13 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Best Shocks for a EK ? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Just shocks? Koni Yellows </TD></TR></TABLE>
Old Nov 30, 2005 | 12:37 PM
Bone Stock's Avatar
Default Re: Best Shocks for a EK ? (94eg!)
anything better then koni yellows?
Old Nov 30, 2005 | 12:58 PM
94eg!'s Avatar
#1 Super Guy
Loved
No (you asked for the BEST).
Old Nov 30, 2005 | 01:10 PM
Bone Stock's Avatar
alright Koni yellows might be it. What would be a good combination with these shocks, like as in springs/struts and the whole deal?
right now he has the tein springs
Old Nov 30, 2005 | 01:55 PM
94eg!'s Avatar
#1 Super Guy
Loved
Ground control makes the best coil-overs, and they are the only ones that have special coil-overs to fit Koni shocks (no other brand works). Everything has lifetime warranty to original customer, and those two companies have the best customer service in the buisness.
If he's going 2" or lower, he should buy a pair of ground control upper mounts, or research the "shock fork mod"...
FYI: Ek's don't have struts, they have shocks. Only 2001+ civics have struts on the front...
Old Nov 30, 2005 | 02:07 PM
Bone Stock's Avatar
sturts as in sway bars and strut bars and all ther other monkey bars
Old Nov 30, 2005 | 02:30 PM
alwaysoverkill's Avatar
best shocks Koni Yellows....best option for that $1000 is completely different since for $1000 you can get a good set of coilovers, Buddy Club Racing-Spec, Tien Flex/SS, Koni Yellow shocks with custom rate Ground-Control coilover springs...lots of options.
or, for $1000 he can get Koni Yellows ($460 shipped) with Ground-Control (GC) coilover custom rate springs ($339+shipping) and still have enough for a 22mm Integra or Civic Type R rear sway bar, but a subframe reinforcement kit would be needed and would push the budget to about $1100 total.
plenty of options available, but best shocks only for general use is Koni Yellows and the only thing within $1000 or less that will offer great performance.
Old Nov 30, 2005 | 02:31 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote">anything better then koni yellows?</TD></TR></TABLE>
For the price they are very hard to beat.
Old Dec 1, 2005 | 12:42 AM
Bone Stock's Avatar
Are koni yellows and tein S springs good combination?
Old Dec 1, 2005 | 04:58 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote">sturts as in sway bars and strut bars and all ther other monkey bars </TD></TR></TABLE>
Those are all completely different things. Shocks and stuts are both types of dampers (they dampen the spring motion) and look similar, but are slightly different in their application. As said before, 2001+ civics have struts, earlier has shocks.
Sway bars should be used to tune the suspension, and added after you've got a good setup (shock / springs) already. Strut [tower] bars are a brace that goes from one shock mounting to the other, but really don't have too much effect on handling. All those other bars realy don't do anything at all.
EDIT: any you can't beat Konis. I'd run them with stock springs for a while, and if that's not good enough, upgrade to Eibach springs or GC coilovers.
Old Dec 1, 2005 | 09:42 AM
Koni Yellow + Tein S tech is a complete waste of the Yellows. Tein S-tech has incredibly soft rates and dosen't even require Tokico illuminas. KYB GR-2 would work with those soft Teins. Most people go yellows to use with stiff suspension like custom rate ground-control.
Old Dec 1, 2005 | 12:09 PM
nonsense's Avatar
Default Re: (alwaysoverkill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysoverkill &raquo;</TD></TR><TR><TD CLASS="quote">Koni Yellow + Tein S tech is a complete waste of the Yellows. Tein S-tech has incredibly soft rates and dosen't even require Tokico illuminas. KYB GR-2 would work with those soft Teins. Most people go yellows to use with stiff suspension like custom rate ground-control.</TD></TR></TABLE>
I wouldn't go as far as saying that. Koni's with stock shocks would be a great improvement over stock or replacement shocks. There are lots of people in stock class autocross that use Konis with stock springs. They can lower it a bit and the adjustability improves handling.
Plus if he goes that way he can buy the shocks now, then later upgrade to coilovers without having to get new shocks. I ran Koni yellows with pro-kit springs for about a year and loved the setup. I recenlty bought GC's and the konis are still going strong.
If I was this guy and had $1000 burning a hole in my pocket I'd drop it on Koni/GC's.
Old Dec 1, 2005 | 12:40 PM
Bone Stock's Avatar
Default Re: (nonsense)
where can i find GC coils and Koni yellow shocks for the best price?
Old Dec 1, 2005 | 03:43 PM
custom rate GC $339+shipping from ground-control.com (road race) gives you the choice of rates or call them.
$460 shipped for yellows from the marketplace section of this forum. total price around $800-$820 for both.
Old Dec 2, 2005 | 05:01 AM
ecahatch's Avatar
Senor Miembro
Default Re: Best Shocks for a EK ? (AutoXer)
OTS ground controls are fine i heard......but i love my customs! 500/450
Old Dec 2, 2005 | 05:03 AM
hondachick81's Avatar
I have been completely satisfied with KYB AGXs...
but that is all I have every used, so
I know none other.
Old Dec 2, 2005 | 09:20 AM
Kendall's Avatar
If you want the absolute BEST then consider Moton, Ohlins, or Penske. But none of those will fall anywhere near the $1000 budget.
Old Dec 2, 2005 | 09:33 AM
EGNA's Avatar
i have tein ra's on my eg and their splended
definately recommend them, a bit more than a grand tho
Old Dec 2, 2005 | 01:07 PM
Tein RA's are extreme stiff ratesfor EK - 783F/559R
also they are $1500 for EK, I looked into them, but decided on Buddy Club instead
Old Dec 2, 2005 | 03:07 PM
Bone Stock's Avatar
thanks guy i appreciate all the help
Old Dec 3, 2005 | 11:50 AM
chrisw85's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">If you want the absolute BEST then consider Moton, Ohlins, or Penske. But none of those will fall anywhere near the $1000 budget.</TD></TR></TABLE>
Motons for a DC2/EG is about $5790 for double adjustable, $6400 for triple and about $10,100 for four-way adjustable damper sets. Then you have to buy the springs!
but, it'd be the best $5k+ you'd spend on your car short of safety and seat and track time in my opinion.
Old Dec 3, 2005 | 10:37 PM
bmoua's Avatar
koni yellows or kyb adj...i just got some kyb adj on my EJ8 and man...i love them...
allmotorlsbaby
Suspension & Brakes
Mar 1, 2009 11:17 AM
run-it-red
Sep 15, 2005 05:43 AM
zseeanz
10
Oct 30, 2003 08:50 AM
