HX wheels
Old Nov 30, 2005 | 08:11 AM
OH_SNAP10k_SHIFT!'s Avatar
Default HX wheels
does anyone know if hx wheels fit dc2 chassis? i know lug pattern is the same, but will it clear the brakes n all since they are 14"? also, more importantly; how much does it weigh?
Old Nov 30, 2005 | 09:15 AM
lazie's Avatar
no the calipers are too big and will rub the wheels. the wheels weight aprox. 11lbs
you can try a few things to make them fit, you can grind the caliper down or just get wheel spacers
Old Nov 30, 2005 | 11:37 AM
Default Re: (lazie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazie &raquo;</TD></TR><TR><TD CLASS="quote">no the calipers are too big and will rub the wheels. the wheels weight aprox. 11lbs
you can try a few things to make them fit, you can grind the caliper down or just get wheel spacers</TD></TR></TABLE>
yeah thats what i figured. thank you. i just needed light wheels to put drag radials on. ill prolly just find light 15" wheels. thanks again.
Old Dec 1, 2005 | 02:24 PM
jerm50's Avatar
yes they do fit, i used a 3mm or 4 mm spacer on the front ands nothing on the back and they fit perfect.
Old Dec 1, 2005 | 02:54 PM
teamvirus's Avatar
My car breaks a lot!
Default Re: (jerm50)
you could put a washer on each of the studs, which will make enough space 4 the rim to fit
slow_redcivic
Jan 25, 2006 05:32 PM
12 oz.
May 9, 2003 11:29 PM
Jonathan_ED3
Oct 28, 2002 04:32 PM
b18c1-ek
Feb 13, 2002 06:46 PM
LeftCorner
Jan 8, 2002 07:07 PM
