loss of low end torque
Old Mar 13, 2002 | 05:14 PM
2001silvergsr's Avatar
Default loss of low end torque
I have JDM type r swap and just got the JDM DC 4-1 header with carsound cat. I have also had my throttle body honed to 64mm. Car is used to autox. I was told by a shop that this could cause a loss of low end, because header has to flow more to produce scavenging effect with exhaust gases. I know I helped top end but will it be that noticeable in low end and in autox situation. BTW Im running USDM DC 4-2-1 with test pipe and apexi WS exhaust. Should I leave that set up or put on my new one?
Old Mar 13, 2002 | 05:29 PM
Black R's Avatar
25 Year Member
Default Re: loss of low end torque (2001silvergsr)
.....why not try it and see? Or better yet, dyno so you can compare graphs.
I haven't heard that one before.
Sounds like an elusive "backpressure"/ old wives tale the shop is telling you.
Old Mar 13, 2002 | 06:26 PM
Default Re: loss of low end torque (Philly_01_ITR_Driver)
I understand the improvements on top end, I speaking from autox point of view. Sometimes you get in lower rpm range in turns. Or if you screw up a little you drop rpms, just wondering if anyone autox with this exhaust set up? I will definately try it, but will be bummed if I lose alot of bottom end torque. What rpms does the increased flow make noticable difference, when vtec kicks in (5800 on mine) or before?
Old Mar 13, 2002 | 06:28 PM
B2FiNiTY's Avatar
If the RPMS drop too low then downshift.
Old Mar 13, 2002 | 06:48 PM
Default Re: loss of low end torque (B2FiNiTY)
I will have this on by Friday and give my opinions. Next autox is 3-23-02 and I will try it out. Hopefully I keep revs up and love my set up. Just did not want to waste $420 on stuff that could be negative for what I use my car for.
Old Mar 15, 2002 | 07:52 PM
Well just had header and cat installed. It screams from 7500 to 8500 rpms. I have to say Im happy . Tuesday I will have my 64mm TB put on. Wed my Konig Greenlights arrive and also a set of Axis Ultimate brake pads for front. Im doing a complete flush of brake fluid and bang, Autox on Sat. So far, so good, Im very happy. It is amazing how a type r motor makes power above 7500 rpm. I cant stop revving it, drove around for an hour tonight ripping the **** out of my car. Not that I street race but I whopped a riced out teg. Dude even had the chrome fire extinguisher and gauges on a pillars. Beat his *** by 2 car lengths. Hopefully Ill be succesful on Autox coarse!
dc2long
Jun 10, 2006 04:42 AM
beat_nut
22
Nov 17, 2004 07:00 AM
8krdline
Apr 1, 2004 06:05 PM
ahhhhhhh
Feb 5, 2004 05:02 AM
Brett
Nov 10, 2002 12:46 PM
