B series crank snout diameter?
Old Nov 30, 2005 | 07:04 AM
d16dcoe45's Avatar
Default B series crank snout diameter?
I am curious to know the diameter of the crank snout on b-series motors. Most d-series crank snouts are 24mm diameter, some of the older ones (88) are 22mm. The reason I am interested is because Fluidamper and ATI don't make dampers for d-series motors, so I am interested in possibly adapting one from a b-series. Could someone measure the ID of the crank pulley or the OD of the crank snout on their b-series motor? thanks.
Old Nov 30, 2005 | 08:16 AM
743power's Avatar
Default Re: B series crank snout diameter? (d16dcoe45)
26.97mm
Old Dec 1, 2005 | 09:43 AM
d16dcoe45's Avatar
Default Re: B series crank snout diameter? (743power)
thanks alot man. So I guess my idea wouldn't work without welding material on. I was hoping it was the other way around (d-series larger crank snout than b-series)-so all that would've been needed was opening up the hole on the damper. Oh well.
Old Dec 1, 2005 | 12:57 PM
743power's Avatar
yea, the b-series is definitely bigger. i think my measurement is off, but it is def. bigger than an inch.
quik sol
May 23, 2006 04:01 PM
Justin Jones
Nov 26, 2005 04:48 PM
