best way to remove window tint
I just did mine--- go to Wal-Mart and get Ammonia. By the cleaning products. Just mix it with some water and spray it on. Let it sit a few mins and then use a razor blade to get it going and to remove the excess residue. Pretty easy actually. Just try to pull it off in one piece.
I just did this. Although I work at Mazda it was easy for me to get this stuff but it shouldn't be too hard at a automotive store. Get some solvent and scrub the crap out of it. Also make sure the tint is warm as it will be easier to remove (I figured this one out the hard way, 2hrs of scrubbing). If you got a defrost on the back then you just scrub like crazy. No razor blades on the back.
when i peeled mine off it left some glue on the windows. "Goo Gone" took that right up! Plus it wont get you as high as some of the other chemicals you can use!
