rear seats removal
EASY EASY EASY... you'll need a 10mm wrench for ONE bolt. That's it. These instructions are for my hatch, but the 4 door should be CLOSe, but because it's not a divided rear seat, it'll be a little off for the seat back. Still, it's HeLLa Easy.
Forst, put the seats in the folded down position. Look at the outsides where the fenderwell is inside the car. In the hinge for the seat, between the seat pad and the plastic panel there's a little clip thing. It is a "c" clip, just pop is off on both sides. This will allow the seat backs to move side to side slightly. Push the seat to the outside of the car as far as it'l go and the middle will come off of a peg in the center. Do this for both sides, and you're half way there.
For the bottom, once the seat backs are out, you can simply unbolt the one 10mm bolt on the driver side center of the lower seat pad. It's almost in the trunk <hint hint>. Once the bolt is out, pull up on the rearward edge of the lower seat pad, and it'll come up to about a 45 or 60 degree angle to the bottom of the car and you'll be able to pull up to remove the lower seat.
Easy, eh?
[Modified by SiR Kid, 8:12 PM 3/13/2002]
Easy, eh?
Nocturnal
Jan 7, 2003 11:42 AM
