will the b16a flywheel and clutch assembly fit on the b18b?
Old Nov 29, 2005 | 09:46 PM
the.hamburglar's Avatar
Default will the b16a flywheel and clutch assembly fit on the b18b?
i have an exedy stage two clutch from the b16 and was thinking about buying a lightweight flywheel for the b18b because im doing a b16 to b18b swap. the b16 blew. so just wondering if its all a direct swap? clutch and flywheel. i know my b16 lsd tranny will work. thanks
Old Nov 30, 2005 | 07:36 AM
jdmcars.com's Avatar
Default Re: will the b16a flywheel and clutch assembly fit on the b18b? (the.hamburglar)
The clutch/flywheel is dependent of the transmission, not engine block.
Meaning, that if are you running the same transmission, the same clutch/flywheel will work.
Old Nov 30, 2005 | 09:29 AM
Default Re: will the b16a flywheel and clutch assembly fit on the b18b? (jdmcars.com)
so with my b16 transmission ill need to lightweight flywheel for the b16 and then ill bolt it to the b18b motor. easy enough. thanks
Old Nov 30, 2005 | 12:06 PM
debogsr's Avatar
I thought any B-series clutch and flywheel will work for any B -series engine?
Can anyone tell me if im wrong, or verify that im right?
Old Nov 30, 2005 | 12:16 PM
projectTeG's Avatar
Default Re: will the b16a flywheel and clutch assembly fit on the b18b? (debogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by debogsr &raquo;</TD></TR><TR><TD CLASS="quote">I thought any B-series clutch and flywheel will work for any B -series engine?
Can anyone tell me if im wrong, or verify that im right?</TD></TR></TABLE>
the flywheel will work regardless. if you have a 92-01 tranny and a 92-01 clutch then yes it will work. the only clutches that are different are the 90-91, the transmission of the 90-91(small clutch spline) years are different from the 92-01's
93_delsol
Oct 28, 2010 04:58 AM
Unknown Racing
Mar 21, 2007 10:11 AM
DALLEN
Jan 18, 2007 12:04 PM
daidilus
Jan 6, 2006 04:59 AM
hatchmonkey92
Dec 12, 2003 06:30 PM
