gsr block finally done! tell me what u guys think
Old Nov 29, 2005 | 08:12 PM
RomoGuy's Avatar
Default gsr block finally done! tell me what u guys think
http://www.imagestation.com/my...g.jpg
B18c gsr block, honed, ACL main and rod bearings, Arp rod bolts, pr3 pistons, oem water pump, Im aiming for 200whp, I already ordered Omni valvesprings and retainers. can u guys help me out, ideas and thoughts
Modified by RomoGuy at 9:30 PM 11/29/2005
Modified by RomoGuy at 4:31 AM 11/30/2005
Old Nov 29, 2005 | 08:21 PM
Mike@K-Tuned's Avatar
Default Re: gsr block finally done! tell me what u guys think (RomoGuy)
What do you plan on using in the rest of your set-up, like cams, header, etc. Give us some more details.
Old Nov 29, 2005 | 08:30 PM
RomoGuy's Avatar
I was thinking maby Blox stage 2 cams, Aebs Intake manifold, 65mm TB, cam gears, stock valves 3 angle valve job, not sure about header, but im not rich so cant be like a 700 dollar header
Old Nov 29, 2005 | 08:56 PM
Default Re: (RomoGuy)
Better check out the trouble I'm having with my set-up. I am using Blox B's in my 1.8L and I'm having a few probs. Blox B cams might be too big for 1.8L set-ups.
Checkout my post here https://honda-tech.com/zerothread?id=1423907
Old Nov 29, 2005 | 09:34 PM
onepoint6i's Avatar
Default Re: (EGgsrAM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGgsrAM &raquo;</TD></TR><TR><TD CLASS="quote">Better check out the trouble I'm having with my set-up. I am using Blox B's in my 1.8L and I'm having a few probs. Blox B cams might be too big for 1.8L set-ups.
Checkout my post here https://honda-tech.com/zerothread?id=1423907</TD></TR></TABLE>
no...
your header is hurting your vtec crossover, its not the cams....
was that header made for your motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RomoGuy &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by RomoGuy at 9:30 PM 11/29/2005</TD></TR></TABLE>
your pics arent working...
you dont need anything major to make 200whp with your build so far...search and you'll see
Old Nov 30, 2005 | 03:30 AM
RomoGuy's Avatar
can someone help me post them? i tried here are the links
So my setup is too mild? for these cams? are u sure about that? what do u need to run them?
Old Nov 30, 2005 | 05:42 AM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RomoGuy &raquo;</TD></TR><TR><TD CLASS="quote">can someone help me post them? i tried here are the links
Old Nov 30, 2005 | 07:06 AM
onepoint6i's Avatar
Default Re: (RagingAngel)
looks nice!!!!!
Old Nov 30, 2005 | 07:31 AM
EK9-Stealth's Avatar
clean
Old Nov 30, 2005 | 08:30 AM
biggdogg's Avatar
Default Re: (EK9-Stealth)
very nice setup i built one this year too ,but i`m too scared to put it in . o.s. ctr pistons , full arp top and bottom, typeR oil and waterpump .
and here is what it`s going in .....
Old Nov 30, 2005 | 09:37 AM
RomoGuy's Avatar
thanks ragingangel for posting the pics, Man im starting to think maby i should change to CTRs while i have everything taken apart, what u guys think? am i gonna need the extra compression?
Old Nov 30, 2005 | 09:39 AM
CLMTFabEG6's Avatar
Default Re: (biggdogg)
looks nice biggdogg and romo guy. I'm just finishing mine.....afraid to start it though.
Old Nov 30, 2005 | 09:46 AM
biggdogg's Avatar
Default Re: (CLMTFabEG6)
yea , me too .
Old Nov 30, 2005 | 09:52 AM
CLMTFabEG6's Avatar
Oh BTW mines a LSVTEC sorry not a gsr
Old Nov 30, 2005 | 10:50 AM
92Jspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RomoGuy &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking maby Blox stage 2 cams, Aebs Intake manifold, 65mm TB, cam gears, stock valves 3 angle valve job, not sure about header, but im not rich so cant be like a 700 dollar header</TD></TR></TABLE>
have you thought about using flat face valves to give you a little more compression like supertech or omni valves? nice build so far though keep us updated bro
Old Nov 30, 2005 | 11:41 AM
P@@RB@Y's Avatar
What paint did you you for the gold on the block?Looks nice/different.
Old Nov 30, 2005 | 12:58 PM
CLMTFabEG6's Avatar
Default Re: (P@@RB@Y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P@@RB@Y &raquo;</TD></TR><TR><TD CLASS="quote">What paint did you you for the gold on the block?Looks nice/different.</TD></TR></TABLE>
Just standard high temp engine enamel. Had to repaint it cause the block had to get hot tanked twice.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RomoGuy &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking maby Blox stage 2 cams, Aebs Intake manifold, 65mm TB, cam gears, stock valves 3 angle valve job, not sure about header, but im not rich so cant be like a 700 dollar header</TD></TR></TABLE>
I'm running the AEBS manifold and a JG 65mm TB. The 65mm TB matches up perfect to the manifold. I was there when they did the dyno test on the first castings of the manifold......on a jdm itr motor they gained 15 whp straight bolt on, no tuning or anything else, just a straight change over
Old Nov 30, 2005 | 03:21 PM
RomoGuy's Avatar
Actually I was thinking about usings flat faced valves, and possibly milling? but that kinda scares me, what u guy think about milling? any experiences? is 11.3 no where near enough for the blox type b's?
Lol im also kinda freaked out about it all working, but ive torqued everthing down to specs according to my Haynes.
Old Nov 30, 2005 | 03:44 PM
onepoint6i's Avatar
nothings wrong with milling, alot of people dont like it because you obviously cant reverse it...but .010inch is not bad and it'll give a better quench for combustion...
I've seen one of ERICKS racing's head, it was milled past or real close to the indicator.....Of course thats not recomended by honda but thats what they order...
Also go with an oem one layer head gasket or something equal like Mugen/spoon etc...
Old Dec 1, 2005 | 07:14 AM
CLMTFabEG6's Avatar
Default Re: gsr block finally done! tell me what u guys think (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">nothings wrong with milling, alot of people dont like it because you obviously cant reverse it...but .010inch is not bad and it'll give a better quench for combustion...
Yeah I have seen alot of good builds with the head being milled, but like onepoint6i said once its done its done no turning back.
Old Dec 1, 2005 | 09:22 AM
RomoGuy's Avatar
I have an original honda headgasket, I heard someone saying something about taking off a layer, was he just being smart? or is that actually possible
Old Dec 1, 2005 | 09:28 AM
92Jspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RomoGuy &raquo;</TD></TR><TR><TD CLASS="quote">I have an original honda headgasket, I heard someone saying something about taking off a layer, was he just being smart? or is that actually possible</TD></TR></TABLE>
yup you can take the middle layer(i think) out to make a 2pc. gasket and bump the comp up a little.
Old Dec 1, 2005 | 03:38 PM
RomoGuy's Avatar
anyone else familiar with this? or has had more experience? and how much compression is usually needed to bring out the most of the blox type bs
Old Dec 1, 2005 | 03:47 PM
onepoint6i's Avatar
just run 1 layer from the three layers, some say middle some say top some say bottom..i've used all 3..they all worked perfect..
just make sure you use an even coat of copper spray on both sides of the single gasket
Old Dec 1, 2005 | 03:48 PM
92Jspec's Avatar
Default Re: (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">just run 1 layer from the three layers, some say middle some say top some say bottom..i've used all 3..they all worked perfect..
just make sure you use an even coat of copper spray on both sides of the single gasket</TD></TR></TABLE>
good info
