Suspension & Brakes Theory, alignment, spring rates....
$500 to spend on DC spring/shock, get what?
Old Nov 29, 2005 | 07:34 PM
NXLude's Avatar
Default $500 to spend on DC spring/shock, get what?
I got $500 and no more for springs and shocks for my H22 DC2, what do you recommend? Id spend more but thats my budget, it also has upper strut bars and a rear sway bar......if that helps
Old Dec 3, 2005 | 10:47 PM
bmoua's Avatar
i'd say...GC's and kyb adj or kyb gr2's...or h&r sport springs and kyb adj....
Old Dec 4, 2005 | 02:28 AM
kachikosu's Avatar
Spoon fixed damper set.
Old Dec 4, 2005 | 06:13 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: (kachikosu)
Koni yellow shocks and keep your stock spring until you can save enough for a decent set.
Old Dec 4, 2005 | 09:08 AM
Erik95LS's Avatar
Default Re: (ActiveAero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">Koni yellow shocks and keep your stock spring until you can save enough for a decent set. </TD></TR></TABLE>
I second this one
Old Dec 4, 2005 | 02:49 PM
TunerN00b's Avatar
Old Dec 4, 2005 | 04:10 PM
NXLude's Avatar
it has h&R race springs and tokico hp on the shell now......it just sits too low in the front, the h22 oil pan will scrape the ground!
Old Dec 4, 2005 | 08:35 PM
PrinceAli132's Avatar
Default Re: $500 to spend on DC spring/shock, get what? (NXLude)
I think we have a winner
Ali
Old Dec 4, 2005 | 08:40 PM
.E's Avatar
.E
Default Re: $500 to spend on DC spring/shock, get what? (PrinceAli132)
Like the others have said...Koni yellows
Old Dec 4, 2005 | 08:58 PM
NXLude's Avatar
will the h&r race springs sit any higher on the koni yellows? I just dont like how low the front is
Old Dec 4, 2005 | 09:02 PM
Erik95LS's Avatar
Default Re: (NXLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">will the h&r race springs sit any higher on the koni yellows? I just dont like how low the front is</TD></TR></TABLE>
not unless you get the neuspeed konis. Then you can raise the front slightly.
Old Dec 4, 2005 | 11:40 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">it has h&R race springs and tokico hp on the shell now......it just sits too low in the front, the h22 oil pan will scrape the ground!</TD></TR></TABLE>
If you cherish your motor you'd put a little more money in that budget and get a better suspension setup. no complaints about a koni yellow/gc setup. around $700 and you get full adjustablility; damper and height. that's only $200 more than your budget, but thats mad insurance for your motor. well worth it, so don't go cheap!
Old Dec 5, 2005 | 07:13 AM
AutoXer's Avatar
Default Re: (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">
not unless you get the neuspeed konis. Then you can raise the front slightly.</TD></TR></TABLE>
The 'normal' sports are adjustable as well, just less settings than the neuspeed ones.
Old Dec 5, 2005 | 07:23 AM
Erik95LS's Avatar
Default Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
yes, but he wants to raise the front and there is no higher setting on the front shocks of the off the shelf koni yellows. Just a lower one.
Old Dec 5, 2005 | 04:50 PM
NXLude's Avatar
perhaps Ill reconsider my budget. Like I said, its sporting a 280 whp h22, so i want a good suspension, and if it were just me Id spend 1500 on it, but i have to keep a budget or my wifey will kill me......Ive noticed omni coilovers going for 650, how do those compare to a gc/koni setup?
Old Dec 5, 2005 | 06:01 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">Ive noticed omni coilovers going for 650, how do those compare to a gc/koni setup?</TD></TR></TABLE>
They don't...
Like everybody said, your best best bet would be to buy some Koni sport shocks first. Use your stock sproings on the lower perch setting & it will lower your car about 1.3". Koni designed the lowered settings for your stock springs, so you know you won't run into problems.
Then when you have saved another $330, you can get the ground control sleeves & springs made to fit koni's perfectly. You can even order custom spring rates designed for an H22 swap at no additional charge. If your planing on going pretty low (2" or more), you will also want to pick up some ground control upper shock mounts for the front end ($115 a pair), or research the "shock fork" mod (free) to add some extra compression stroke to your suspension. This keeps you from riding on the bump stops...
None of those other companies can match the lifetime warranty of Koni & GC, and their customer service cannot compare...
Old Dec 5, 2005 | 06:02 PM
94eg!'s Avatar
#1 Super Guy
Loved
***oops***
Old Dec 5, 2005 | 06:47 PM
NXLude's Avatar
Ok.....maybe Ill try to find a set of used stuff or get some gc/konis on sale somewhere to see what all the hype is about
Old Dec 5, 2005 | 08:49 PM
ernald711's Avatar
don't worry it's not hype. the hype will be your reality.
Old Dec 6, 2005 | 05:14 PM
t0ekn3e's Avatar
get konis and use the h&r springs.
Old Dec 6, 2005 | 05:34 PM
NXLude's Avatar
just to save money i might try that first.....then if its still too low i may switch springs
asianalbutt
Dec 30, 2005 10:58 PM
90hbvtec
Suspension & Brakes
Jun 26, 2005 09:06 AM
MSP
Dec 28, 2004 03:05 PM
redacura
Aug 25, 2003 11:01 PM
cracker099
Jan 14, 2003 08:31 PM
