Swap Running: But Horrible Popping Noise
Old Nov 29, 2005 | 03:42 PM
fasterthenmost's Avatar
Default Swap Running: But Horrible Popping Noise
Hi All,
I just wanted to know what you guys think this could be.
I changed the head gasket and the oil is no longer leaking.
Now as the car idle's just fine and drives ok but I keep hearing
a popping noise ( like balloons popping ) I have no idea what this could
be but after just double-checking everything all over again. I began pulling
spark plug wires 1,2, & 3 were all dry but the 4th position was wet with oil.
see picture below for what i mean.
Could it be because this sensor is broken.
I think it is the middle hose above the PCV valve
that connects to this sensor. I did extend the wires correctly
to the sensor. If someone can give me the name of this sensor so that
I can replace it that would be great or even sell me one we be perfect. Below
is a picture of the sensor.
Thanks in advance Honda-Tech
Modified by fasterthenmost at 5:12 PM 11/29/2005
Old Nov 29, 2005 | 04:05 PM
sicones's Avatar
Default Re: Swap Running: But Horrible Popping Noise (fasterthenmost)
did you take the spark plugs out of the engine or just pull the wires, becasue if its only on the wires then you just have a leakey valve cover gasket (the spark plug o ring part)
Old Nov 29, 2005 | 04:10 PM
Default Re: Swap Running: But Horrible Popping Noise (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">did you take the spark plugs out of the engine or just pull the wires, becasue if its only on the wires then you just have a leakey valve cover gasket (the spark plug o ring part)</TD></TR></TABLE>
I changed out the valve cover gasket and the 4 rings for the valve cover.
All are new OEM honda parts. I did not take out the spark plugs just the wires. Should i pull the plug and see if its covered with oil also? Its only the plug closest to the clutch side. All other plugs are dry as a bone. Does anyone think its safe to drive it.....
Old Nov 29, 2005 | 05:13 PM
typeoneeg6's Avatar
put some hondabond around the spark plug tube seals.
Old Nov 29, 2005 | 05:16 PM
komat's Avatar
Default Re: Swap Running: But Horrible Popping Noise (typeoneeg6)
when do you hear poping sound
at idle, while driving or between shifts
idle- could be running lean but i doubt it
driving- misfire i think
between shifts- could be a bad gasket somewhere in the exhaust system
Old Nov 29, 2005 | 05:21 PM
I usually here it after the car temp guage is at half way running at idle after about 4 - 6 mins
Old Nov 29, 2005 | 05:24 PM
Heylookits shawn's Avatar
Default Re: (fasterthenmost)
um....temp gauge shouldnt be going that far. it should only go about 1/4. are you overheating?
Old Nov 29, 2005 | 05:25 PM
its about a 1/4 ... I might of over exaggerated definitely not overheating though....
Old Nov 29, 2005 | 05:30 PM
92ehatch's Avatar
my gauge reads just below halfway, he isnt over heating from his description.
i would definately try new rings around spark plug
Old Nov 29, 2005 | 05:38 PM
komat's Avatar
Default Re: (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">um....temp gauge shouldnt be going that far. it should only go about 1/4. are you overheating?</TD></TR></TABLE>
you have a aftermarket thermostat?? or a lower spec then stock??
a little b4 half way is normal temp
Old Nov 29, 2005 | 05:40 PM
Which one of these are the correct distributor settings...
(1)
or
(2)
I think its backfiring...
Old Nov 29, 2005 | 05:42 PM
komat's Avatar
number 2 is the correct order
Old Nov 29, 2005 | 05:47 PM
stock thermostat and it is a little b4 half way.... guess imma try some silicon around the ring on the valve cover
I was using number 2 on the distributor setting
some else told me to try number (1)
Modified by fasterthenmost at 7:11 PM 11/29/2005
Old Dec 1, 2005 | 04:19 PM
typeoneeg6's Avatar
use hondabond
crazyDC5
Apr 7, 2007 08:07 PM
garageEF
Aug 9, 2006 10:21 AM
kb7709
Nov 29, 2004 12:45 PM
Brian_92GSR
Aug 9, 2002 09:34 AM
