wil the top ground control mounts (extended travel) work with stock strut bar
for 94-99 gsr integra?
not sure if the stock strut bar will get in the way of the extended mounts? if i could modify the strut bar and shave it a little
anyone have this setup
Those extended shock mounts would not let me re-install my OEM integra strut tower bar on my 94cx civic. I looked it up in the archives and it would also seem they interfere with the ITR bar as well. Some people use a dremel to remove some of the material where it was interfering, but I just left the bar off (not much of a difference in performance).
If you've got some money burning a hole in your pocket, you could buy a Neuspeed strut tower bar that mounts to the UCA studs instead. It's a little spendy, but it's one of the best strut tower bar designs.
Sub $1500 "full coilovers" are crap compared to Knoi/GC.
The upper mounts are all but invisible until you hit a bump. That is when their purpouse is realized. The softer bump stops that come with them provide a smooth transition between free movment & bump stop. Plus the added .75" shock travel allows a full 1" of extra wheel travel during compression. Imagine that bumps would have to be a full inch taller to feel as nasty as they do with your current setup...
They get a
from me...
They get a
from me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave »</TD></TR><TR><TD CLASS="quote">Plus they look really cool under your hOoD yO!</TD></TR></TABLE>
There's that too...
There's that too...
VTEConly
May 23, 2004 07:24 PM
Greyout
19
Sep 5, 2003 01:56 PM
