coolant temp sensor / reverse lights / oil pressure light / hard start- car bogs and dies
Old Nov 29, 2005 | 03:17 PM
MOVE OVER's Avatar
Default coolant temp sensor / reverse lights / oil pressure light / hard start- car bogs and dies
My 87 crx si 1.5 L PGMFI motor is throwing code 6 after it starts. (TW sensor) or coolant temp sensor
It is very hard to start, and after a while of idling, it will sometimes instantly die when touching the gas pedal.
I read that someone kept throwing code 6 as long as the reverse lights were plugged in. When I put my car in reverse, the oil pressure light comes on not completely solid, but seems like it has some sort of short. (reverse lights do not work and all fuses were good)
Could these problems be related? my clock fades out and in as well. Same electrical issues? or totally different ?
The car can't be driven now that code 6 is on, it will idle, but after it starts warming up will die when touching the gas pedal instantly !
HELP !
Modified by ITR 1102 at 8:09 PM 11/29/2005
Old Nov 29, 2005 | 09:56 PM
MOVE OVER's Avatar
Default Re: coolant temp sensor / reverse lights / oil pressure light / hard start- car bogs and dies (ITR 1
this forum moves quick !
nobody has any input or ideas ?
Old Nov 30, 2005 | 11:48 AM
MOVE OVER's Avatar
still need help
Old Nov 30, 2005 | 12:37 PM
downest's Avatar
Check on crxresource.org or redpepperracing.com, there are more guys with 1st gen CRXs there.
mycrx7
Jan 23, 2007 11:21 AM
kinvid22
Jan 20, 2007 09:17 AM
rc90hatch
11
Dec 27, 2005 11:05 PM
crx si 2004
Nov 21, 2005 05:59 PM
137
Dec 22, 2004 09:54 AM
