WOW talk about good gas mileage
I just put a CX tranny in my LX civic (5 speed).
In 5th gear....
LX- 3k rpm= 74mph
CX- 3krpm= 89mph!!!!!!!!!!!!!!!!
not good for performance but good @ the gas pump!
In 5th gear....
LX- 3k rpm= 74mph
believe it or not, you may not see an improvement in gas milage. although you are spinning the motor slower to acheive the same speeds, you may have a higher load because of the gearing...if you want to save gas, be easy on the pedal and shift early. on my vx engine, i got anywhere from 25-50 depending on my driving style. on my ls, i can get between 22-35.
It also depends on the torque peak of the motor - where it's making power the easiest. If it's right below the peak, but high vacuum (low load/partial throttle), it's going to give you great milage. [Albeit a flat tq curve wouldn't follow that] That tranny will be putting you at 2.5k at 74mph, which is much farther out of it's torque range than I'd put it. There's a reason every car manual reminds you not to bog the motor.
SOKDO
51
Feb 16, 2005 10:08 PM
