AVS ES 100... hahaha
whats up all. took my integ gsr to the track the past weekend. i had a problem hooking up. the best i could launch it without getting crazy burnouts and wheel hop was 2500. anything over that was just ridiculous. 60 ft. times on 2500 launch 2.33s. at around 2700 i got 3.1s on the 60 foot. tested this a few times since i was able to run it about 10 times. my question is, what is the best street legal tire i can use that has really good hook up on the track?
i know this is not an all motor question. i also posted this in the tire/wheel section. i figured i'd get better responses here than there. thanks in advance
AVS ES100
wet weather
AVS ES100
wet weather
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin »</TD></TR><TR><TD CLASS="quote">get some BFG's</TD></TR></TABLE>
AVS es100's are damn near econo tires.
o wait..they are
o wait..they are
everyone says bf goodrich.. im guessing their drag radials? i've heard that falken rt615 are also sticky... but does anyone know if thats good for just autocrossing or drag also? thanks again guys
I've heard good things about the KDW 2 from bfg also. They obviously wont give as much traction as the radials but have a better longer treadwear rating for street driving
I used to see consistent low 2.2" 60s in my dc2_GSR with 205/50 es100s with about 24.5psi front, 45 in the rear running 14.58-68 at 95ish. The car had about 165-170whp, full int. on the stock tranny. I'm sure the drag radials woulda helped but I found for me that these tires worked well for what I did with them.
my .02
my .02
KDW2>ES100>712, owned all three, currently running the KDW2's, rolled the fenders to fit 225's on 16's and loving them. The BFG DR is not really a daily driver street tire, but I used to have a pair for racing, although the Hoosier DR blows it away if you're going to get a set of track tires. I haven't tried the 615's yet, maybe next.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR »</TD></TR><TR><TD CLASS="quote">I used to see consistent low 2.2" 60s in my dc2_GSR with 205/50 es100s with about 24.5psi front, 45 in the rear running 14.58-68 at 95ish. The car had about 165-170whp, full int. on the stock tranny. I'm sure the drag radials woulda helped but I found for me that these tires worked well for what I did with them.
my .02
car ran 14.50 at 98.38mph with 2.331 60' ft. @ 24psi. im sure if i could launch harder i would've had 14.4 if not lower.
i think i will invest in some bf drag radials.
my .02
</TD></TR></TABLE>car ran 14.50 at 98.38mph with 2.331 60' ft. @ 24psi. im sure if i could launch harder i would've had 14.4 if not lower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">
o wait..they are
Hey man i pulled of a 2.0 60ft with a 13.0@106.7 QT Mile time. They arent too bad, you just gotta know how to drive.
o wait..they are
</TD></TR></TABLE>Hey man i pulled of a 2.0 60ft with a 13.0@106.7 QT Mile time. They arent too bad, you just gotta know how to drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matador »</TD></TR><TR><TD CLASS="quote">
on what chassis?
</TD></TR></TABLE>on what chassis?
i used to pull numerous low low 1.8 60 foots with my n/a car
with bfg drag radials. they're nice tire for na. 205-50-15
if over 225 + whp i'd suggest 225-50-15
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_SNAP10k_SHIFT! »</TD></TR><TR><TD CLASS="quote">
on what chassis?</TD></TR></TABLE>
EG6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K Si FBP »</TD></TR><TR><TD CLASS="quote">i used to pull numerous low low 1.8 60 foots with my n/a car
if over 225 + whp i'd suggest 225-50-15</TD></TR></TABLE>
Yep i wish at the time i went to the track i had some BFGs, now for next season im planning on getting some slicks.
EG6.
I have some es100's and think they are pretty decent. I was getting a consistant 2.25- 2.3 60' times last time I went. I had the fronts down to 22psi. I tried just for the hell of it at 35psi and couldnt hook up.
