Axle too short?
Old Nov 29, 2005 | 12:26 AM
ktp1798's Avatar
Default Axle too short?
I have a 90 hatch with a zc engine, zc tranny, and the correct zc intermediate shaft. I am also using 91 integra axles. I replaced the drivers side axle today with an autozone rebuild and noticed that I barely had a couple of threads coming through the hub. So I went ahead and put the axle nut on (it pulled the axle the rest of the way through) Then I noticed that the rotor wouldn't turn. I loosened the axle nut and it turned fine. Everything looks ok, but it feels like someone is holding the brake when the axle nut is tightened. The passenger side spins fine. What gives?
Old Nov 29, 2005 | 08:21 AM
ktp1798's Avatar
Help!!
Old Nov 29, 2005 | 08:29 AM
jlicrx's Avatar
Default Re: (ktp1798)
take the little rubber dust ring off the outer CV joint - it is binding up in the hub
Old Nov 29, 2005 | 08:39 AM
JDMified's Avatar
Just remove the dust cap rings from the ends of the axles and theres also some on the inside of your hub...they pop right of with a flat head screwdriver.
Old Nov 29, 2005 | 08:51 PM
ktp1798's Avatar
Thanks for the replies. It was the hub rings.
wubanga
17
Jul 8, 2009 09:09 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
mykal
14
Aug 30, 2004 12:18 PM
Passaudi1.8t
Jan 15, 2004 10:45 PM
ill phil
May 15, 2003 06:27 PM
