CT: da, dc, wideband garage sale.
Old Nov 28, 2005 | 11:58 PM
JDMorgan's Avatar
Default CT: da, dc, wideband garage sale.
hey, i am just trying to get rid of a bunch of stuff. i don't have any pix on this pc, so sometime in the next couple days everything will have pix. everything is best offer. i have alot of honda/acura parts so if you need something just let me know.
-AEM UEGO gauge w/ sensor. brand new, removed from box to test gauge out. wo2 sensor was never installed on a car. paid $450, will take offers.
-RC 310cc injectors from greddy turbo kit.
-B17A1 shortblock, slight rust on cylinder walls from sitting.
-B16A Block w/ b18c1 main caps, girdle, windage tray, pickup, and oilpan. slight rust in cyl walls from sitting in my garage. no crank.
both motors would be fine if bored over. plans were to make a 1.7L b16a, w/ os itr pistons.
DA:
-blue privacy cover
-black privacy cover
-black dash with small cigarette burn on the top.
-90-93 headlights with clear corners, if i remember right one fog has a broken clip. stays still when driving but won't aim.
-90-91 passanger side taillight, good shape.
-90-91 passanger side taillight, some scratches.
-92-93 driverside taillight, good shape.
-rear disc brake setup.
-brake master cylinder, booster, and prop valve.
-obd0 vtec distributor, mint.
-obd0 non-vtec distributor, mint.
DC:
-94 LS hatch with holes for wing. scuffed up black, good shape.
-94 GSR wing with broken studs, black.
-94 front bumper. black, good shape but the paint is in horrible shape. needs to be sanded down and repainted.
-94 clear corners.
-94 headlights, decent shape. could use a good polishing.
-94 LS 2dr Floor harness, +door harnesses. car had power windows + mirrors, but manual locks and no sunroof.
-black 99 gsr dash, dash is modified to accept 52mm gauges where cruise and dimmer switches would be. slight scuff on driverside above cluster, airbag was deployed. no vents.
-steering column plastics.
-stock gauge bezel.
-LS cluster.
WTB:
-OBD1 GSR distributor
-OBD1 GSR ECU
-OBD2A -> OBD1 ECU Harness.
Old Nov 29, 2005 | 11:00 AM
JDMorgan's Avatar
Default Re: CT: da, dc, wideband garage sale. (KraZEtEggIE)
bump
Old Dec 2, 2005 | 11:26 PM
. M i c h a e l's Avatar
dotmichael to you
15 for the DA black cargo cover?
Old Dec 5, 2005 | 09:39 AM
JDMorgan's Avatar
any1 want this rear disc conversion? it takes up so much darn space, i would like to get rid of it asap.
Old May 26, 2011 | 07:24 AM
aron5hauck's Avatar
is that obd0 vtec distributor you have for a b series???????
Old May 26, 2011 | 08:05 AM
hardcore97's Avatar
il give you 175 shipped for the wideband
stevenmannn
Northwest (Sales)
Aug 13, 2008 05:17 PM
swifty4u
Northeast (Sales)
Oct 24, 2006 10:18 PM
naujcdl
Aug 10, 2004 05:23 AM
thaimonkee
Apr 18, 2003 08:02 AM
