need help with parts list 4 a jdm d15b v-tech swap
Old Nov 28, 2005 | 11:38 PM
91civic4drboy's Avatar
Default need help with parts list 4 a jdm d15b v-tech swap
i got a 91 one 4door civic and i need help cuz i dont really kno wat i need 2 get so i can make the swap.........i have the motor and wiring harnees and that all
Old Nov 29, 2005 | 07:18 AM
beyondspexj's Avatar
well you should convert to obd1 while your at it so you will need:
the motor of course
keep your tranny
keep your axles
obd0-obd1 conversion harness
obd1 fuel injectors ( 92-95 ) and matching pigtails
4 wire o2 sensor
p28 ecu
now thats the cheapest way but what i would also do while the motor is out is:
get a y8 intake manifold
b16 tb and port match the manifold to it
get an si transmission
aftermarket clutch
lightweight flywheel
Old Nov 29, 2005 | 07:10 PM
Default Re: need help with parts list 4 a jdm d15b v-tech swap (91civic4drboy)
taxks tat helps a lot.............lets say im not trying 2 do it the cheap way
EF'n Broke
Oct 14, 2006 11:12 AM
d16y8delsol
Feb 20, 2006 12:58 PM
racingant
Jul 21, 2005 10:02 AM
Bjorn20
Jun 21, 2005 04:05 PM
