Gap at flange to pipe connection?
Old Nov 28, 2005 | 09:44 PM
5thgencivic's Avatar
Default Gap at flange to pipe connection?
I did a quick search but didn't come up with anything. I'm going to start back purging and was wondering if there should be a gap between the flange to pipe connection just as there is between the pipe joints? Head flange, turbo flange, wastegate flange, etc. Thanks for any input
Nate
Old Nov 29, 2005 | 06:37 AM
david@didrace.com's Avatar
Default Re: Gap at flange to pipe connection? (5thgencivic)
Depends more on the thickness of the material than anything. If you can do it in a single pass you probably won't need a gap but if it's a multiple pass piece either bevel the pieces or leave a small gap. A bevel would be better just because you won't be wasting as much argon.
Old Nov 29, 2005 | 07:05 AM
Default Re: Gap at flange to pipe connection? (backpurge)
Ok. I mostly just deal with schedule 10 and 1/2" flanges. A good bevel and no gap is something I will try. Thanks.
danielm3
Welding / Fabrication
12
Mar 2, 2006 06:24 PM
9civic8
10
Oct 15, 2005 06:51 PM
u2civic1
Aug 30, 2005 09:47 PM
rice a roni
17
Apr 8, 2005 07:58 AM
