What is the difference between an 88-89 Si and the 90-91 Si?
Old Mar 13, 2002 | 01:01 PM
Aahj's Avatar
Default What is the difference between an 88-89 Si and the 90-91 Si?
I know that one difference is the fact that the 90-91 CRX Si comes with rear disc brakes.
are there any other differences?
thanks in advance,
aj
Old Mar 13, 2002 | 01:12 PM
4g4me's Avatar
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (ajn)
90-91 has a cooler round guage bezel
90-91 has cooler front bumper w/scoops
about it as far as cosmetics.
Old Mar 13, 2002 | 01:16 PM
LSBeast's Avatar
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (4g4me)
The front bumper is different
Old Mar 13, 2002 | 01:31 PM
Urban Business
Guest
Posts: n/a
seatbelts mounted on door of 90-91 side trim is jdm looking on 88-89
Old Mar 13, 2002 | 01:54 PM
Smokinsax's Avatar
The Boot
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (TorteX)
rims are also different
Old Mar 13, 2002 | 02:16 PM
evo's Avatar
evo
New User
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (Smokinsax)
Also what's the differemce between SIR &SIRII.
Old Mar 13, 2002 | 02:47 PM
Smokinsax's Avatar
The Boot
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (evo)
depends on what you are talking about. I assume you mean the b16a1 and the b16a2. Go to http://hybrid.honda-perf.org/index.html , they can answer any question you have regarding that
Old Mar 13, 2002 | 04:04 PM
Rick's Avatar
90-91 tail lights have a black border where as 88-89 don't.
Old Mar 13, 2002 | 05:00 PM
DJ KrunchyKracker's Avatar
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (Rick)
ok i am kinda confused by all this. i have an 89 crx si and my seatbelts are in the doors. and i have the scoops on my front bumper for brake cooling (actually for JDM fog lamps). im pretty sure i have drums in the rear. i havent removed my rears yet since my car was crashed and it has been sittiing in the garage. im gonna have to check this out tomorrow. and i know that they parts arent changed from another car because this was a one owner clean title car that was owned by some old retired guy living in some LA suburb. if anyone can explain please go for it.
Old Mar 13, 2002 | 06:18 PM
CRXtc 90's Avatar
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (TheRZA28)
look to see when the car was made if it is from about august through december then it is considered a 90
Old Mar 13, 2002 | 06:21 PM
wronghand's Avatar
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (CRXtc 90)
The 88's were the only year they didn't use the door mount seat belts. The HF is the exception they kept the pillar mounted seat belts for 89. Hope this helps.
Old Mar 13, 2002 | 07:22 PM
flat-blk-HB's Avatar
i also hear 88 is the lightest year because the pilar mounted belts...this would make the doors lighter then 89-90-91 because they are mounted on the door i think adding weight to them...i think....
Old Mar 14, 2002 | 10:32 AM
evo's Avatar
evo
New User
Default Re: What is the difference between an 88-89 Si and the 90-91 Si? (89EF-BCUMBIE)
I actually mean JDM EF.
[Modified by evo, 7:38 PM 3/14/2002]
SnarlaHazard
Nov 11, 2015 03:59 PM
em Dot
12
Aug 9, 2006 12:17 PM
khunt0012
Feb 3, 2005 10:28 PM
importboi22
May 10, 2004 05:27 AM
B_CRUZ!
Aug 6, 2002 07:10 PM
