Code 8 on a ZC?
Old Nov 28, 2005 | 05:40 PM
ex voto's Avatar
Default Code 8 on a ZC?
Anyone have any ideas? On the stock D16A6 it's the TDC sensor, and I'm sure that's the same on the ZC. Is it in the same location? And what's the best way to fix it?
Thanks... I've searched, but not a lot of code 8s that I can see.
Old Nov 29, 2005 | 05:53 AM
ex voto's Avatar
Default Re: Code 8 on a ZC? (ex voto)
TTT
Old Nov 29, 2005 | 06:18 AM
jlicrx's Avatar
TDC sensor is in same location in Si and ZC distributors - best way to fix it is get a new distributor - was this in a running car and then code showed up or is this in a new swap?
Old Nov 29, 2005 | 06:23 AM
ex voto's Avatar
Default Re: Code 8 on a ZC? (jlicrx)
It was a running car and then it showed up. Just got done re-ringing the pistons and putting on a new timing belt tho.
Old Nov 29, 2005 | 08:44 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ex voto &raquo;</TD></TR><TR><TD CLASS="quote">It was a running car and then it showed up. Just got done re-ringing the pistons and putting on a new timing belt tho. </TD></TR></TABLE>
are you sure the timing belt is not off one tooth on the intake camshaft?
Old Nov 29, 2005 | 09:21 AM
ex voto's Avatar
Hrm... you make me second guess myself. Let me see if I can figure that out...
ef_zc
Aug 12, 2008 06:04 PM
omgwtfbbqcrx
Jun 11, 2007 07:20 PM
White91EF
May 23, 2007 10:23 PM
ZCHF
Aug 11, 2004 07:26 PM
