EG front swaybar?
I am tryin to make sure that to install a itr front swaybar on my 94 dx hatch all i will need is the
Swaybar
Endlinks
Bushings
LCA's from a 94-01 teg
i have searched but not found anything thanks in advance
Swaybar
Endlinks
Bushings
You will need the following:
2 x2
3 x2
4 x8
15 x2
24 x4
25 x2
26 x2
Remember, you will also have to drop your exhaust & shift linkage to get the bar in. Just be prepared. Also, take extra good care of those balljoint studs. I Fucked those up when I did my swaybar replacment...
2 x2
3 x2
4 x8
15 x2
24 x4
25 x2
26 x2
thanks that is exactly what i needed. so my stock eg LCA's will work thank you. and one last question is will i have any clearence issues with the itr front sway bar or everything wll clear
If your car didn't come with a front sway-bar, then your stock LCAs won't work. Your going to need all those parts I listed from the integra...
Actually there are two different types of Integra front swaybars. The 22mm one is the one in my last post, the 24mm one is #2 in the picture below. Both sizes of sway-bar have their own specific bushings (#3) & end-links (#18 or #6), so make sure you have the correct ones...
PS: No you won't have any interference problems...
and what is the web sit for oem acura parts if there is one, because i have the site for hondaautomotiveparts.com but nothing for acura and thanks again
the endlinks are different with the 24mm sway bar? so what endlink bushings can i buy to replace the oem ones?
man, i was wondering why my endlinks looked different this whole time...i bought ES endlinks and it didnt bend 90 degrees like the ones on my endlinks
i was also wondering if the 24mm energy suspension greasable sway bar bracket and bushings would work in place of the oem ones. anyone here know???
The ES brackets may work, but the OEM ones are not quite the same. The side that bolts directly to the chassis has slightly longer reach than the side that bolts to the LCA mount. I would stay with OEM brackets & OEM rubber bushings there...
A lot of times you can find the same Integra parts on the "94 only" Del Sol VTEC for a few dollars less (click here). You should try that first before you order from Acura (infated prices at Acura)...
As for the endlink bushings, they are the same for both types of bars, but the 24mm bar only uses 4, while the 22mm bar uses 8...
drkstrs24
11
Jun 11, 2010 03:00 PM
gamby
Nov 10, 2007 08:31 PM
ESCALVANTE
Jun 7, 2002 11:48 AM
