All Motor B20
So Far Have This In Mind For The Set-Up
Type-R head
Skunk2 pro series
full valve train
70 mm throttlebody
Race Header 4-1
3 angle valve Job
Stock b20 Block want to run the pro serious 3 hope the bottem end will hold up
b16 tranny
welded diff
CM clutch Kit
stage 2 driveshafts axle systems
Still researching some parts for the build
Type-R head
Skunk2 pro series
full valve train
70 mm throttlebody
Race Header 4-1
3 angle valve Job
b16 tranny
welded diff
CM clutch Kit
A stock B20Z block with the PHK pistons even with the dremmeled out valve reliefs for bigger valve to piston clearence still will not create enough compression to run these cams to the full potential, You'd have better results with pro 1's IMO. But either way GL!
DrGrEeNtHuMb
Jul 30, 2009 04:30 AM
99b18
Oct 26, 2004 08:55 AM
hotintegranights
Apr 7, 2004 01:38 PM
Shark Tank
Sep 20, 2002 01:13 PM
