JDM H22 parts?
Old Nov 28, 2005 | 03:34 PM
Specail Ed's Avatar
Default JDM H22 parts?
So where are you guys getting your JDM parts at? I'm not 110% about JDM, I'm just looking for a distributor cap and rotor. I switched from the internal coil, stock on JDM H's, to an external coil so I could buy USDM parts. I really don't like the MSD coil set up I'm using, with the wires running out of the cap. I was looking to put the stock coil back in, but where can I score caps and rotors at? Any help would be great.
Old Nov 28, 2005 | 03:39 PM
Turbogixxer's Avatar
Default Re: JDM H22 parts? (Specail Ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Specail Ed &raquo;</TD></TR><TR><TD CLASS="quote">So where are you guys getting your JDM parts at? I'm not 110% about JDM, I'm just looking for a distributor cap and rotor. I switched from the internal coil, stock on JDM H's, to an external coil so I could buy USDM parts. I really don't like the MSD coil set up I'm using, with the wires running out of the cap. I was looking to put the stock coil back in, but where can I score caps and rotors at? Any help would be great.</TD></TR></TABLE>
I order for a 92-95 civic cap and rotor. Never had a problem. Leave the MSD **** off the car, it will hurt you more then help, OEM.
This is if you have a OEM dizzy, if you have a dizzy king, you need to buy one of theirs.
Old Nov 29, 2005 | 05:18 AM
Specail Ed's Avatar
Default Re: JDM H22 parts? (Turbogixxer)
So a 92-95 Civic cap and rotor will work on a JDM OEM distributor? I didn't know that. That's helps me a ton. Thanks.
Specail Ed
Feb 12, 2008 10:30 AM
dmxsoulja3
Mar 13, 2005 06:19 PM
mister2racer
Oct 7, 2003 02:18 AM
dominate9
Aug 24, 2003 03:37 PM
