hesitation during acceleration
Old Mar 13, 2002 | 11:11 AM
manson's Avatar
Default hesitation during acceleration
My first what's the problem post
Anyways... I just picked up a 92 integra gsr. Its great, but i personally don't know anything about the car maintenance wise.
Okay so between 2000 and 3000 rpms i get a small amount of bucking like i'm running out of gas. I've been told to check/change my fuel filter, injectors, distributor, plugs and wires. I have a brand new distributor on it as of 100 miles ago so thats not the problem. Is this information accurate? I plan on doing a full make over when i get her back from the body shop so everything will be changed, but i just want to make sure i passed it past you fine people before i go switch all this stuff and then i still have the problem because i left something out ya know.
thanks in advance
Old Mar 13, 2002 | 11:23 AM
yellowbuffalo's Avatar
Default Re: hesitation during acceleration (mansonclubpuir)
it could be the tranny anyways change all the fluids tranny, oil, etc
Old Mar 13, 2002 | 11:26 AM
manson's Avatar
Default Re: hesitation during acceleration (slipknot23)
i don't think its the tranny... the car stops reving. that would lead me to believe that the tranny has nothing to do with it.
Old Mar 13, 2002 | 12:06 PM
shmitty350's Avatar
Sounds like an ignition/fuel delivery issue. Pull sparkplugs and inspect, replace the fuel filter cause thats probably due anyway, also examine the sparkplug wires for any damage.
HTH,
Rich.
Old Mar 13, 2002 | 01:47 PM
RedTeg95's Avatar
Default Re: hesitation during acceleration (shmitty350)
I had the same problem recently.
My solution... PLUG WIRES!
It was a pain to trouble shoot because I did not have any timing light or extra wires. All the stuff I could inspect visually checked out. By the time I got done with that all the stores where closed, so I called a buddy who is a DelSoler who put a B18C in his car who luckily had both a light and wires laying around and Whalla! Wire to cylinder 1 was bad. What really threw me with this problem was it was very intermittent.
Hope this helps.
Good Luck
Old Mar 13, 2002 | 01:55 PM
GSRaCeRbOI's Avatar
Default Re: hesitation during acceleration (RedTeg95)
to test the wires you can start the car up in a dark place (garage, dark street, etc) make sure its well ventilated so you dont die from the exhaust.. anyway see if the wires have sparks/arching when you start it up.... you can also pull each wire and check for continuity w/ a multimeter while bending/moving the wire around to see if there are any "breaks" anywhere that would show up on your multimeter..
also check your spark plugs, cap/rotor, replace your fuel filter, check your ignitor.. even if nothings wrong.. it wont hurt your car to change these anyway..
[Modified by GSRaCeRbOI, 10:56 PM 3/13/2002]
Old Mar 13, 2002 | 03:20 PM
qwikenuf's Avatar
ignition timing too far back?
gsilnc
Jun 21, 2010 09:48 PM
99blusi
Jul 13, 2006 10:03 AM
craiger369
Jun 16, 2006 07:14 AM
blacK_Dc4
Apr 24, 2005 11:34 PM
89JDMcrx
Sep 9, 2002 11:11 AM
